Go to Post Look at FIRST 7 years ago. Look at FIRST now. Thanks Bill. - Steven Donow [more]
Unread 11-01-2010, 06:52
DiehardCybercard's Avatar
DiehardCybercard DiehardCybercard is offline
zaba do de da, FIRST
no team (AndyMark)
DiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud ofDiehardCybercard has much to be proud of
Effective Drive Base
What are everyone's opinions on what could be an effective drive base for this year and why do you think so?
I had a thought of a swerve drive with treaded wheels. The treaded wheels could provide the necessary traction to move over the BUMPS but the swerve drive provides extreme mobility.
Brett Heininger
AndyMark, Inc. Web & Media
Unread 11-01-2010, 07:46
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
Re: Effective Drive Base
I agree. Crab (swerve) drives will most definitely be effective this year.
Mecanum drives will also be effective, because they are both able to get up the bumps and move with extreme maneuverability and moderate speed. The one downfall is that they have to be dead perpendicular to the ramp, or they will just drive sideways along it.
I think the best drive trains will be those built specifically for this game, such as a drive like this one:
http://www.youtube.com/watch?v=xby0SOphLUg
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 11-01-2010, 10:22
Chrono101 Chrono101 is offline
FRC #1448
Chrono101 is an unknown quantity at this point
I keep thinking tank treads would be a good idea. The bumps would be no problem whatsoever.
Unread 11-01-2010, 10:29
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I tried this year to think about not using my favourite drivetrain (our linkage). But the more and more I thought about it, the more and more I think that our system would work out well. Basically a swerve system with a little less mobilty and less complexity should be well and capable of climbing bumps in at least one or both set ups.
Unread 11-01-2010, 11:43
no team (AndyMark)
a graduated member of my team suggested using belts that have been flipped inside out to use as tank treds
Brett Heininger
Unread 11-01-2010, 11:50
Chris is me's Avatar
AKA: Pinecone
Some things to consider if you want a swerve drive. Will it high center? How will it climb? Can it take the shock load of falling off the bump? Do you have the resources to ensure this works?
And unfortunately, Simswerve looks somewhat impossible this year. Design idea number 40 billion killed by bumpers.
Unread 11-01-2010, 12:23
dustinjeremy2k's Avatar
dustinjeremy2k dustinjeremy2k is offline
FRC #1153 (RoboRebels)
dustinjeremy2k is on a distinguished road
I'd like to encourage teams to draw lots of diagrams, mock up rolling chassis, and think about the assumptions you are making before designing a "drive base".
Basics
4WD skid - simple, effective, stable climber. If it's designed to stand a chance in a pushing contest, it won't be very maneuverable.
6WD skid / tank tread - a bit heavier, more moving parts, NOT a very stable climber, much more maneuverable, still good at pushing (Usually the best "compromise" chassis, but not this year).
Omni / Holonomic - very versatile, simple, maneuverable, but you're on roller skates, and can't climb well (or at all).
Crab / Swerve - similar to above but with superior traction, superior handling, more complex, many moving parts, not likely to be a good climber. Does not (usually) rotate the chassis efficiently which could lead to more complex (multi-sided) game mechanisms.
I think the best drive systems will be some sort of hybrid between two of the basics. I would NOT use a tread or a crab to climb... good luck to those who try it! (And do you really need to climb anyway?) If you do, you might want to bring a big tool box to the competitions!
Enjoy!
Unread 11-01-2010, 13:46
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
Basics
Enjoy!
Why would a tank tread design do poorly while climbing those bumps? I've heard the exact opposite: that tanks are great at it, and that they *almost* never break. I'm on an iPhone, so I can't link to YouTube, but search up the Ripsaw MS1 made by Howe and Howe Tech (yeah, the ones from discovery channel).
Unread 11-01-2010, 14:16
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Drive system mobility and ball control are going to be the two most important aspects of robots this year, and likely the two most over looked in the design process.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 11-01-2010, 14:22
dtengineering's Avatar
AKA: Jason Brett
Basics
Enjoy!
The advice about checking assumptions and making design drawings and models is excellent, and there is a good list of drive concepts to consider here, as well.
However I would strongly encourage teams to check the assumptions made in the "basics" section of this post for themselves by looking at successful ramp climbers from the Aim High game, and step climbers from the First Frenzy game. Some of what is listed there, although no doubt well-intentioned, doesn't reflect my personal observations of drive train abilities over the past six years.
Jason
Unread 11-01-2010, 14:35
AKA: Pinecone
Jason
You beat me to this post.
Never rule out unconventional drivetrains that would seem like a waste on a flat field either. Maybe it's not so good to limit your options to the 5 drivetrains on that list. I don't know.
I would completely rule out swerve drive if you've never built one before. Knowing your limits is key.
Unread 11-01-2010, 15:04
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
What is the reasoning behind not using a crab to climb?
Unread 11-01-2010, 15:20
Basics
Enjoy!
Your reasoning behind many of these suggestions is very flawed. Your references to 6wd robots that fail to climb the ramp are inaccurate generalizations. I have yet to see a ramp that a well designed and well thought out 6wd with very good CG cannot overcome.
Also, this may be the year we see a 6 wheel swerve system. Although I would never doubt someone like WildStang designing a 4 wheel system that can overcome the bump this year.
Unread 11-01-2010, 15:34
CraigHickman
Posts: n/a
Tracks. Finally we have a year where tracks are useful again! As for the weight concern, how does 18lbs for simple track modules sound? 38 for simple modules with gearboxes and motors?
I like this year.
Unread 11-01-2010, 15:58
run the trap!!!
Team Role: Human Player
When I first started analyzing the game I figured that a basic 6 WD robot with 8" wheels could easily climb the bumps. In this configuration there is no bottoming out issues, and the CG can be kept quite low.
However, we discovered a critical flaw when we tested this.
When a 6 WD robot climbs a ramp*, the center wheel acts as a pivot as the robot climbs over the crest. This results in half the robot being lifted into the air Highly unstable!
Take a look at the demo bots in the game vid (The non-animated ones of course!). They all have FOUR wheels. This is a much more stable configuration b/c all four wheels remain in contact as the robot climbs. There are no sudden rocking movements forwards or back.
Of course, as Dean himself pointed out, 4 WD robots don't turn very well...
*or a tracked drive
-Philip J. Fry
pic: drive base idea dbell Extra Discussion 23 26-07-2008 11:11
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
Drive Base Advice archiver 2001 0 23-06-2002 22:57
