Go to Post We treat productive freshmen the same way as everyone else. As for excesively ambitous new people, we have one rule:what happens in the hotel, stays in the hotel... ;) - Crop-Circles [more]
Unread 10-01-2010, 11:00
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
2010 Mabuchi Motor Specs....
This goes out to all the EE Sparkies out there...
Any sign of a new motor spreadsheet for 2010 KOP motors?
And specifically... , anyone know the difference between the
RS555SH-2670
RS555VC-3754
Motors?
Thanks.....
Phil Malone
http://www.GEARSinc.org
Unread 10-01-2010, 14:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 2010 Motor Specs....
Google yields some results. Both motors appear to be in the range of ~40W peak power if I recal. Not very powerful, but still may be useful.
Unread 11-01-2010, 10:54
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
RS555VC - HERE
RS555SH - HERE
Collin Fultz
Unread 11-01-2010, 16:20
jc4p jc4p is offline
AKA: Kasra Rahjerdi
FRC #2412 (Robototes)
jc4p is an unknown quantity at this point
Originally Posted by Collin Fultz View Post
RS555VC - HERE
RS555SH - HERE
Thank you.
Unread 11-01-2010, 19:55
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
RS555VC - HERE
RS555SH - HERE
Can we use the banebots transmissions for these motors?
Unread 11-01-2010, 20:00
According to Section 8, as long as they're under the cost limits (and you use these specific motors), there are no limits on COTS transmissions and gearboxes.
Unread 11-01-2010, 20:10
I think you misunderstood the question . I was wondering is it Possible to use the banebots transmission?
Unread 11-01-2010, 20:14
You'll probably need the right pinion gear, but it looks like you should be able to.
Unread 12-01-2010, 02:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Regarding the RS-555SH-2670, I searched Google with RS-555SH-2670 filetype:pdf, and got four useful results, including three that referred to that exact part number. The fourth was the one linked above, but it doesn't specify that it's the -2670.
  • From Ignis: 24 V, 8 200 rev/min free, 0.14 N·m stall, 7.00 A stall, 0.16 A free => 7.56 W max. at 12 V.
  • From Kinmore: 12 V, 4 500 rev/min free, 0.11 N·m stall, 4.40 A stall, 0.19 A free => 13.29 W max. at 12 V.
  • From Globalsources: 12 V, 4 500 rev/min free, 0.11 N·m stall, 4.40 A stall, 0.19 A free => 13.29 W max. at 12 V.
  • From Compucanjes (cited above): 24 V, 8 500 rev/min free, 0.23 N·m stall, 9.00 A stall, 0.18 A free => 12.52 W max. at 12 V.
The last ones are quite similar (once you convert them to 12 V), but the first is way off. (I don't think it has anything to do with the gearbox, since the torque values are not scaled as you'd expect if the gearbox were included.) I can't find a good reason to ignore the first set of data—which refers to this motor by number.
Maybe I'm missing something (so feel free to check my math). Either way, it appears that this isn't a very powerful motor.
Unread 12-01-2010, 13:35
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
It looks like the 36 mm gearboxes from BaneBots line up.
The previous years' RS540/550 motors have the same 25mm mount pattern and 3.17mm shaft
But sadly BaneBots only has one type of gearbox 64:1 for the 36mm sizes
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 12-01-2010, 13:44
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The P60 series is also designed to accept the RS-540/545/550/555 motors and has a wider range of available ratios
Unread 12-01-2010, 13:59
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
While on the subject of these two motors, has anyone been able to locate a source for spares?
Unread 27-01-2010, 18:28
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Straight from the horse's mouth...
Hi all,
It has taken almost 3 weeks but I finally tracked down the right guy at Mabuchi who could give me the official skinny on the 2010 KOP Motors (thanks to my past life as a electromechanical guy at GM/Delphi, the folks at Mabuchi return my calls ;-)
Special shout out to
Chris Tate
Sales Engineering Manager
Mabuchi Motor America Corp.
Now for the specs...
RS555SH-2670 at 12V (note curves in the specs are at 24V)
  • Free Speed = 4200RPM
  • Stall Torque = .11 N-m
  • Stall Current = 4.5A
  • Peak Power = 12W
RS555VC-3754
  • Free Speed = 4000RPM
  • Stall Torque = .28 N-m
  • Stall Current = 12A
  • Peak Power = 30W
See specs for packaging and more details.
Cheers,
Joe J.
Team #88, TJ2
Unread 27-01-2010, 19:38
Re: 2010 Mabuchi Motor Specs....
Great work finding these specs, Joe.
One little thing: my interpolation of the provided -3754 graph gives stall current of 10.9 A, not 12 A, stall torque of 0.29 N·m, not 0.28 N·m, peak power of 30.5 W, not 30 W, and free speed of 4 050 rev/min, not 4 000 rev/min...although those differences would probably be within normal variation anyway.
2010 Denso WIN motor specs Jonnadiah Motors 12 01-02-2011 20:04
Mabuchi motor gear specs? Salik Syed Motors 1 11-01-2005 20:25
Mabuchi Motor Specs Conor Ryan Motors 4 11-01-2005 10:50
Mabuchi Motor Specs Joe Johnson Motors 2 08-01-2002 16:55
