Go to Post Mentor: How is that held in place? CAD Lead: Go to the hardware store and buy a bag of constraints and put the constraints on the robot. - Kenyow [more]
Unread 11-01-2010, 00:28
ashoji12 ashoji12 is offline
FRC #2090
ashoji12 is an unknown quantity at this point
Re: Spiral Drive
well i was thinking that you could get like 2" ABS or PVC and then wrap the treads from the Plaction wheels from andy mark in a spiral thus not violating any rule about damage to field or metal contact with the ground
also if you had 4 of them i think that then it would have the ability to turn like a tank and move horizontally like omni wheels
please correct me if im wrong
Unread 11-01-2010, 00:33
Re: Spiral Drive
Correct on not violating a rule (unless unforeseen results happen).
Correct on turning like a tank.
However, moving sideways will be horribly inefficient, due to the amount of traction generated by the treads. You may even get enough to destroy the treads, or break them loose from their attachments. At that point, consider mecanum or omni wheels, as either will allow you to go sideways.
Unread 11-01-2010, 09:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Spiral Drive
The problem with this idea is that the spiral works by having the ribs slide easily over the surface, and the conveyor belt treads like that do not slide on carpet at all. And the rules seem to prohibit any type of thing that would, as it would likely be considered to be a "cleat".
Unread 11-01-2010, 11:14
Re: Spiral Drive
I would envision this could be made legal using specific materials. The other factors I also considered is the space in which you have to work and the power of the motors available. 29 x 36 is a small footprint in which to add four of these devices. You also will not be able to climb very well without having the center line of the screw be fairly high. I am guessing with all the limitations, a screw could not be made to climb the bump due to the size and power needed.
Unread 11-01-2010, 12:14
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Spiral Drive
I like this, simple to bulid
Team 1946
TEAM 1946-Tamra
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
