Go to Post Facebook for FIRST already exists. It's called Facebook :) - dcarr [more]
  #31   Spotlight this post!
Unread 03-01-2010, 14:36
Re: Serial to CAN Gateway in new Black Jaguars?
Originally Posted by ajlapp View Post
Are the CAN connectors on the Jaguars able to pass data through if they have no power. Are they simply unions or is the Jaguar doing something with the info?
The CAN connectors are pass throughs, and do operate without power. The Jaguar does not act as a repeater.
From my experience with automotive CAN bus layout, we always have a main trunk with a terminator. Each CAN device then has a direct link to the trunk...nothing is daisy-chained. Would this help eliminate failure concerns, excluding losing the main Black Jaguar or the trunk line?
CAN is nominally a daisy chain / trunked layout. What you are referring to is a "vampire tap", a short deviation from the trunk. The signal reflects off of the end of each of the taps, which can cause signal integrity issue if the tap is too long for the bitrate (when in the bitlength does the reflection hit)? If they are kept short and the bit rate is kept low, its a perfectly reasonable way to run a CAN bus.
We decided that it would be better to avoid the issue entirely and go with a purely daisy chained approach. This allows for a higher bit rate and is much easier to assemble and is cheaper. Also, I'm not entirely convinced that a tapped topology is more reliable; Who is going to make the wiring?
I'm not saying that tapped is universally inferior to daisy-chained. I'm just saying that it isn't appropriate for FRC.
  #32   Spotlight this post!
Unread 04-01-2010, 17:12
www.divsys.com's Avatar
www.divsys.com www.divsys.com is offline
www.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud ofwww.divsys.com has much to be proud of
Supply of the new Jag's wont be a problem...
  #33   Spotlight this post!
Unread 05-01-2010, 16:52
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
Hi folks,
I am happy to announce that TI and Digi-Key have rolled out the FRC2010 promotional price for the MDL-BDC (Jaguar) and the brand new MDL-BDC24 (Black Jaguar).
See you at Kick-Off in Manchester!
Jaguar Microsite - check now, check back after Kick-Off:
http://www.luminarymicro.com/jaguar
Digi-Key order link:
http://ordering.digikey.com/Promotio...mpetition.aspx
-Scott
Scott Emley
Marketing Manager
Texas Instruments
  #34   Spotlight this post!
Unread 05-01-2010, 16:58
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Thank you Scott.....I look forward to doing business with you again!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #35   Spotlight this post!
Unread 05-01-2010, 21:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by utlinebacker View Post
Hi folks,
-Scott
Scott,
Can you tell us if the durability improvements that you guys added to the black jaguars are also included in the standard gray ones this year? Specifically the issues surrounding losing one direction on the Jags?
  #36   Spotlight this post!
Unread 05-01-2010, 21:57
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Originally Posted by Tom Line View Post
Scott,
Yes, that would be nice. I was wondering the same thing. I heard that because the black Jaguars can handle up to 24V, it should be better (but I don't know what the failure point in the old Jags was so this may or may not help).
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
  #37   Spotlight this post!
Unread 10-01-2010, 19:31
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
To add a question to the growing list here..
Since CAN is now available, does it mean we can exploit/use use encoders, and/or the Analog pins for a pot connected directly to the Jaguar?
I haven't been able to find a definitive yes or no. Hence I'm asking if anyone else has found out/determined?
Thanks
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
  #38   Spotlight this post!
Unread 10-01-2010, 20:51
1075master's Avatar
1075master 1075master is offline
SLEEP IS POINTLESS!!!
AKA: John Nelson
FRC #1075 (Sinclair Sprockets)
1075master is an unknown quantity at this point
In setting up our teams DS and such I noticed on the FRC updates page of WPI there is a link relating to the CAN network. The information was supposed to be available already but it isn't. I would take a guess that alot of the questions regarding its usage this year will be in there when it gets released.
2004 && 2006
-driver,head design, head build, secondary programmer
year >= 2007 && year <= 2009
-mentor in every aspect
  #39   Spotlight this post!
Unread 11-01-2010, 08:50
Thanks
Michael,
<R60> The control system is designed to allow wireless control of the ROBOTS. The Classmate PC, FirstTouch I/O module, cRIO-FRC, speed controllers, relay modules, wireless bridge, batteries, and battery charger shall not be tampered with, modified, or adjusted in any way
L. If CAN-bus functionality is used, limit switch jumpers may be removed from a Jaguar speed controller and a custom limit switch circuit may be substituted (so that the cRIO-FRC may read the status of the limit switches).
I will need to investigate this as I thought the limit switches were direct inputs to the speed controller micro. This rule implies that the CAN bus must read and process the status of the limit switches.
  #40   Spotlight this post!
Unread 11-01-2010, 12:23
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Al,
While that addresses whether limit switches may be connected to the Jaguars it does not address whether we may connect potentiometers to the analog input or encoders to the encoder input on the Jaguars.
<R68> says sensors or other custom electronics may be connected to the CAN bus, but does not say they may be connected directly to a Jaguar. This connection method is necessary to utilize the position or velocity control modes of the Jaguar.
  #41   Spotlight this post!
Unread 11-01-2010, 12:47
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
<R63> Each Jaguar speed controller must be controlled with signal inputs sourced from the cRIO-FRC and passed via either a connected PWM cable or a CAN-bus connection.
A. The Jaguar must receive signals via either a PWM cable -OR- a CAN-bus connection. Both cannot be used simultaneously.
I previously recall someone mentioning that both pwm an CAN cables had to be connected to a jaguar for a heartbeat message. It sounds to me like this isn't the case.
My interpretation: Since a Jaguar is a CAN node on the CANBus....anything connected a port on the Jaguar is now on the CANBus.... which is allowed.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
  #42   Spotlight this post!
Unread 11-01-2010, 14:35
Tony and Kevin,
Our posts seems to raise more questions. I however read Sec. 8 as the only allowed inputs to a Jag are the limit switches. Other sensors that have a CAN bus interface are allowed to live on the bus to be used by the Crio to interpret and provide command to the bus. It would appear in the way the rules are written, that the Crio is to be the only command device for motor control. A quick glance through the Jag documents does not suggest that sensor inputs to the Jag are echoed out onto the bus. They are simply used by the internal controller to affect the output to the motor.
  #43   Spotlight this post!
Unread 11-01-2010, 14:38
Although I can not speak for the GDC, my interpretation is that encoders and potentiometers are allowed to be used with the Jaguars. My recommendation is to:
1) Move forward under the Yes assumption
2) Have a back-up plan
3) Ask the question.
  #44   Spotlight this post!
Unread 11-01-2010, 17:50
Venturelli Venturelli is offline
FRC #1382
Venturelli is an unknown quantity at this point
You have at least received the Black Jaguar? Our team not!
  #45   Spotlight this post!
Unread 11-01-2010, 18:00
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
The connection of both CAN cables and PWM cables is only necessary if the CAN bus is being spoken to through an "untrusted" interface -- one for which a "trusted" driver is not being used. The definition of "trusted" here is more-or-less a driver that is certain to be obeying the enable/disable signals and can inform the Jags that it is doing so. If the Jags are not informed that the CAN messages can be "trusted" then it will require the PWM heartbeat.
At the moment, the only "trusted" driver that I am aware of is that which uses the serial port on the cRIO and assumes it is connected to a black Jag as a serial->CAN bridge. See http://firstforge.wpi.edu/sf/frs/do/....canjaguar/frs
All that said, the rule as written seems to deny the use of "untrusted" CAN. I obviously do not know if that was intentional.
Where can we get PS2 type game controllers with serial ports? waialua359 Control System 12 25-01-2006 22:33
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
VXML Gateway to Web Databases Adrian Wong Rules/Strategy 11 08-10-2001 08:10
