#16
Re: Team 135 Field Done!
Wow! Are you guys coming to Muncie Scrimmage this year? *hint* *hint*... |
#17
Where did you order the memory foam?
#18
Great job, it looks great!
Where did you order the foam, I cannot find any info on it in the FIRST drawings or field description. We were thinking of buying a Mattress Topper from Costco or Sams. I saw one on Amazon too but am not sure how thick it should be. Seems we can get 1.5 - 3 inches thick. Also foam desity varies with supplier. http://www.amazon.com/Serta-3-Pound-.../dp/B000BI3OWW ![]() |
#19
Wow that is amazing!
Team 2502 was kicked out of our high school at 8PM without any advance notice. Monday morning will be some hectic cleaning before classes start ;-) |
#20
Excellent you beat us! Are you pumped?
#21
The pics were kind of small so I couldn't tell for sure, but it looks like there are no vision targets on that field. Could you not determine the dimensions of the target? I don't see anything in the drawings that give the target dimensions.
#22
The vision target dimensions are in section 6 of the manual. The target has an outer diameter of 42" and each circle (white-black-white) is 4" wide.
#24
It's in the rules, section 6.2.6.
#25
The field is not difficult to build this year. I made a quarter of the field in about 10 hours with only one other person helping.
Best of luck teams. |
#26
I will have to get back to you on the foam, one of the students on the team said that we had ordered it and I will look into it.
And about facebook at school, you should make friends with your IT department, maybe get them as one of the mentors. I say that because I work for the IT department for our team's school, and they do get special treatment since I am a mentor. |
#27
We spent around $400. That is only raw materials.
#29
Be wary, this can turn into a mentor/student build debate easily. If that's on your mind, I suggest searching any of the numerous wars (oops, threads) on here for the opinions previously posted.
| Team 135 Finished Robot | Unholypulpit | Robot Showcase | 5 | 04-03-2009 15:45 |
| Team 135 Autonomous | Team 135 | Robot Showcase | 28 | 18-03-2008 17:50 |
| Team 135 Track Course | chaineezee | General Forum | 8 | 05-01-2008 17:51 |
| pic: Dermot_135 (135) | Dermot_135 | Extra Discussion | 1 | 22-03-2006 11:15 |
| Team 135 proto 1 | CarpeDiem | Robot Showcase | 2 | 23-01-2006 21:26 |
