Go to Post So remember, no matter what the odds, your wildest dreams can come true with science and technology. - Ian Curtis [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 11-01-2010, 14:05
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Re: What do you think will be important this year?
Originally Posted by Chris is me View Post
It can't be.
Since the ball has to be touching the carpet, and can only be 3 inches under the robot, you can't catch it and have it roll down a ramp into a mechanism, as it's being funneled and thus its direction of travel sticks with you when spun.
Also, metal on carpet.
True, although there's still nothing against say, making the top of your robot such that a ball will bounce off of it in a given direction (i.e. angle the top of your robot). This is not an active mechanism, so we don't have a problem there (It's not even really a mechanism). It is in fact a method to avoid carrying balls as it will cause them to roll or (more likely) bounce off.
It is difficult to determine to whether a ball rolling down a ramp (with no side boards) is carrying because if the robot turns, the ball will probably remain in approximately the same absolute position (pulling a tablecloth from under glasses if you will). In addition, any movement in the other degrees of freedom (moving forward, back, left, right) would certainly cause a difference in relative position. As such, I would suggest that a ball rolling down would not qualify as possession, and therefore does not qualify as carrying.
As for the metal on carpet issue, that is not arguable because it is explicitly stated in the rules.
Unread 11-01-2010, 14:15
Chris is me's Avatar
AKA: Pinecone
That is true, and I expect a lot of robots to incorporate this kind of thing into their designs. Without direction, it seems having a ball consistently land in a place close enough to a robot that it would not need to move in order to score would be impossible.
The "metal on carpet" was referring to locking into the carpet.
Unread 11-01-2010, 14:36
Alumnus
I am aware of what "metal on carpet" was referring to (as an example 71 used filecards one year IIRC). I meant was that its illegality is not able to be argued against because it is specifically stated in the rules.
[IMG] code is Off
What do you think the AVA topic will be this year? Kevin Thorp 3D Animation and Competition 14 14-01-2008 17:31
What do you think will happen....? slickguy2007 General Forum 7 29-01-2007 18:39
what do you think high score will be nuggetsyl General Forum 13 03-04-2006 14:03
What do you think this year's competition will be NAMED? Elgin Clock General Forum 18 10-01-2004 19:35
Do you think this years game will be... Brian Savitt General Forum 26 09-12-2001 22:43
