Go to Post your chain routing is cute - rachal [more]
Unread 11-01-2010, 14:40
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
New Festo valve 24v?
The new Festo valve we got is 24vdc. Is this what every one else got?
Festo finally sends us a really nice valve and we can't even use it.
Unread 11-01-2010, 14:45
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: New Festo valve 24v?
And you didn't get any 12v optional solenoids with it? Very odd.
All i can say is check the kop list to see if you were intended a 12v version, and if so let FIRST (or whoever the organizer of this is nowadays) know that they made a mistake and you should have the correct version sent to you.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 11-01-2010, 15:02
IndySam's Avatar
I already checked with the KOP and they are supposed to be 12vdc. I would just like to see what other people received.
Unread 11-01-2010, 15:07
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
ours says 12/24 volts, and seems to trigger properly on 12
Unread 11-01-2010, 15:18
IndySam's Avatar
Hmmmm, ours just says 24v and a 12v battery wouldn't fire it. Two batteries together did.
Unread 13-01-2010, 10:57
The Festo valve has 24VDC printed on the side, but 12/24VDC printed on the ends.
Unread 13-01-2010, 18:23
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
EDIT: Does anyone have a link to buy them?
http://www.festo.com/cms/en-us_us/9697.htm
This provides the link to the old 2009 one. For some reason the link in the excel sheet that FIRST provided is wrong.
-RC
R.C.
MadTown Robotics Team 1323
Unread 15-01-2010, 16:27
IndySam's Avatar
From the new pneumatics manual
FESTO has also supplied one double solenoid valve.
Instructions in the package explain how to wire the valve. The fittings
are the push to connect type so all you have to do is push in the tubing. The
valve is a 24V valve and must be connected to a Solenoid Breakout board that is powered
from the 24V supply on the Power Distribution Board.
Unread 15-01-2010, 16:39
Interesting...
They updated the wiring diagrams to explain how they want it done, too.
http://usfirst.org/uploadedFiles/Com...ution_RevA.pdf
Unread 16-01-2010, 09:04
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Originally Posted by Mark McLeod View Post
Interesting...
I must be missing something then. It looks to me like the NI9472 is still switching 12V in that picture.
Unread 16-01-2010, 09:24
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
If you look in the diagram, there are three sheets. You will see that in the sheet that shows how to wire for 12V AND 24V solenoids that there are TWO (2) NI9472 modules instead of just one. One (1) is wired to the regular 12V 30A max connections. The other one (1) module is wired to the 24V connection, the same connection that you wire the cRio to. If you just want to wire up for 24V you won't need to wire up one of the NI9472 for a 12V connection, and vise versa if you only need to do it for a 12V connection.
Take a good look at the diagrams they updated, and just pay close attention to where the wires lead to.
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
Unread 16-01-2010, 10:04
ayeckley's Avatar
AKA: Alex Yeckley
My fault - I didn't realize it was a multisheet PDF.
Unread 16-01-2010, 10:24
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
my question is why haven't we recieved our valves yet? Secondly we would like to have 4 pnuematics fire at the same time, does any one have a suggestion and a link of a good solenoid that we could use or should be order 3 more FESTO solenoids?
Unread 16-01-2010, 11:06
Mike o.'s Avatar
AKA: Mike O'Brien
A big question would first be what is the application of which you are using the pistons for? Also, how big are they? You can use branch connectors and using tubing to put them into a parallel system. I would be cautious though, because there is the possibility of running into a problem of pistons not firing at the same rate or pistons having the same amount of pushing force as it would if just connected to an individual solenoid. There are many things that you need to take into account and sometimes do a little math and physics.
Bottom line, just look at the application that you are using it for, test it out (prototyping over and over again never hurts, and its always fun), and think it through. Hope this helps.
Mike O'Brien
Unread 16-01-2010, 11:16
ayeckley's Avatar
AKA: Alex Yeckley
Which valves are you referring to? The only solenoid valve in the KOP this year is the FESTO. If you were referring to pneumatic cylinders, you have to request them from Bimba - they are not included in the KOP. You can also purchase additional cylinders if you need more than the three provided by Bimba, or if they don't have what you are looking for. Make sure you know the rules before you do that.
The single FESTO valve provided can control as many pneumatic cylinders as you like if you want them to actuate simultaneously. You can plumb them in series, in parallel, or a combination of the two. You can use the tubing and fittings provided, or you can purchase additional ones if you need. Everything is subject to the 2010 Rule Book, of course.
If you haven't already discovered it, the 2010 Pneumatics Manual has recently been released. It's located under Section 8 of the Competition Manual on the FRC website. It is a must-read document if you are considering using pneumatics on an FRC robot.
24v selenoid valve Tottanka Pneumatics 4 09-07-2008 12:47
Festo valve help Hastypickle Pneumatics 9 15-02-2008 09:17
Link to Festo Valve Assembly Info Scott358 Pneumatics 0 04-01-2003 17:17
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
