Re: Sideways Hanging - Yes or No
I don't see why it wouldn't be legal. It doesn't have to lift that high, only enough to get the wheels off the gound, so it won't put that much side stress on the tower.
Brian |
While there doesn't seem to be anything wrong with it... Why would you hang this way other than the "normal" way? Or other non-normal ways?
And yes you could design a gripper that could let go easy enough. |
From the definitions in 7.2: ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED. Either way, once you are off the ground its the same amount of force no matter how high you go. |
As to why do this.... Well this way, you don't have to reach 7 ft in the air to lift. And you can just as easily lift from under the ball return. The towers shouldn't flip unless you're doing something very wrong. The base plate is an 80" piece of aluminum plate, so it'd extend about 18" out from the tower on each side. A single robot should have difficulty tipping the tower. Front to back, anyways. As far a strength.... A 150lb robot with an 18" CoG will put a bending load on a tube of about 50% yield, if you only grab one pole. I don't have a convenient calculator at hand for point load crushing force on tubes, but you can reduce the crushing force significantly by simply spreading your "hands" out father. Finally... It's dirt simple to make a grasping mechanism for this that releases without power. The dude in the video could have managed just as well with a hook for a left hand and a bunch of friction tape. |
The Team Drawings in the document section: http://www.usfirst.org/roboticsprogr....aspx?id=16097, specifically TE-10012.pdf within 2010 Team Field Elements.zip, show a version of the tower using 4X4's as the vertical posts.
If these drawings are official, then it seem the GDC did not intend for robots to attach to the towers using the vertical posts. If they did, then these drawings are invalid for the official game. Someone need to post a clarifying question in Q&A about this. |
#7
That drawing is for the low-cost field for teams to practice on and in this case does not accurately portray the official field due to different material (1-1/2" steel tubing vs 4x4) . |
#8
we are definatly looking at this option. It was brought up by a couple of students day one as a way to hang. I'm sure the GDC built the tower strong enough to support it. It says the tower was built to support many robots. and I shall trust that.
Also... could you imagine the reaction if a robot broke the tower???? ![]() |
#9
hi can someone tell me how to post a message in the forum please
#10
i can only relply to other peoples, can't figure out how to post a new thread, where to go after i sign in??? thanks
#11
Listen, I am going to assume the GDC thought of teams hanging from the vertical poles.
And they are steel bars affixed at both ends. Maybe if there were 3 robots (~500 lbs) hanging 6 feet directly out from the tower, the thing may bend, but (I don't think) brittle fracture would occur. But if you have 2 robots hanging off your robot in that orientation, your robot's arm will bend way before the steel support (unless your arm is a firmly planted pole of equal size). If we know the phase, thickness, and modulus, we can calculate yield stress and whether the bar will fail catastrophically. Maybe the K1c value too ...Coolness factor outweighs riskiness IMO. Last edited by coldfusion1279 : 13-01-2010 at 10:48. Reason: typo |
#12
Edison go to the forums in the orange bar at the left top of the screen. Pick a topic and at the top of the screen it will say "new thread" or something like that. Also I would pm (private message) you but I am afraid you wouldn't know how to read it. PM's are in your user cp and you can message anyone on the forum privately. There are rules etc. that you should read before posting
#13
Don't be too sure of this. The pole is in bending (shear) while the robot is in compression/tension.
#14
Think of it this way, force applied to the vertical support is applied parallel to the floor, but the weight of the robots is applied perpendicular to the floor. This is assuming a design like the original posting. |
#15
The top left one should say either forums or portal: If it says portal then click on it and it will take you to the portal anf the top left one will then be forums. When it says forums, click on it ... that'll take you to the forums list. Then click on the forum you wish to add your thread to. Once there there will be a blue button that says new thread (looks like the post button) |
| Sideways Driving | zzz | Rules/Strategy | 8 | 08-01-2008 01:37 |
| Mounting the ES17-12 sideways orientation | SuperBK | Electrical | 10 | 21-01-2007 09:38 |
| Sideways vs Forward Speed of Mercanum | ggoldman | Technical Discussion | 1 | 20-01-2007 11:06 |
| Can the Cameras be mounted Sideways? | vicecityman666 | Technical Discussion | 1 | 29-01-2005 10:21 |
| Sideways mounting | srjjs | Electrical | 13 | 25-01-2003 20:31 |
