Go to Post Some advice I wish I had as a college freshman: If you don't understand it, or are struggling to keep up, ask for help. - DonRotolo [more]
Unread 11-01-2010, 14:16
s133p s133p is offline
FRC #0675
s133p is an unknown quantity at this point
Question 2010 Camera and vision problems.
After working most of last build season trying to get the camera working, and ultimately failing. We are hoping to get the camera set up and working this year.
The problem is that it doesn't. The camera works when plugged in to the laptop, both through the NI vision assistant and the web interface. However, when plugged into the cRIO, nothing works. Running the default code that came with this years kit (C++ in windriver) there is no response. Also, the link light on the port that the camera is plugged into on the cRIO doesn't light up.
So far I have tried everything I can think of and I have hit a dead end. Has anyone here had any luck getting the camera working? Any suggestions?
Thanks in advance,
-Luke (675)
Unread 11-01-2010, 14:21
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: 2010 Camera and vision problems.
Are you using a crossover cable when you plug it into the cRIO?
Eric
Unread 11-01-2010, 15:20
FRC #0675
Eric,
Yes, we are using a crossover cable to connect. Are we supposed to be using something else? The crossover cable that attaches it to the cRIO is the same as the one we used when attaching it to the PC.
-Luke
Unread 11-01-2010, 15:28
Many (most?) modern laptops are smart enough to compensate if you use / don't use a cross over cable by switching internally. It is possible that your laptop is tricking you by this method.
Try plugging a hub or switch into ethernet port 2 on the cRIO. Does it light up now?
Unread 11-01-2010, 16:02
The crossover cable in the kit last year was orange. The other ethernet cables in the kit were not crossover cables.
Unread 11-01-2010, 16:16
FRC #0675
We have used the orange cable. And the cable we are using now is a crossover (We tested it). If I plug the computer into port 2, the lights do come up just as they do if the computer is plugged into port 1. (Although there are no comms with this method). Because of that I am reasonably sure the port is okay.
In reference to another thread on here, I made sure the Camera to Dashboard program compiles and is on the robot. And if I have a debugging console running there are no errors reported :-/
This is really irritating.
-Luke
Unread 11-01-2010, 16:25
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
-Luke
Try ouputting data to the debugging console indicating when a command is successfully completed, that way at least you know the code is running correctly.
Unread 11-01-2010, 16:27
jc4p jc4p is offline
AKA: Kasra Rahjerdi
FRC #2412 (Robototes)
jc4p is an unknown quantity at this point
Which camera to dashboard program are you using?
The "Camera to Dashboard" example program does not work to my knowledge. Either build the "FRC 2010 Vision Demonstration" program, or add this to your robot's main code:
AxisCamera &camera = AxisCamera::getInstance();
camera.writeResolution(k320x240);
camera.writeBrightness(0);
You will have to also do:
#include "Vision/AxisCamera2010.h"
If you do this and your camera still does not send an image to the laptop, then it is definitely not a programming problem.
Unread 11-01-2010, 16:33
FRC #0675
DanDon: The code has that, and every part completes as expected.
jc4p: Ahhh, I will give that a go when I get back to the laptop. Is the transmit to the DS auto-magic from that point, or should I also include the PCVideoServer?
Thanks again everyone for all the help. Ill report back after I test again.
Unread 11-01-2010, 16:35
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
I believe that in the WPIlib documentation it says that an AxisCamera instantiation automatically invokes a PCVideoServer.
Unread 11-01-2010, 16:37
FRC #0675
Okay, thanks. I think I was just looking at the wrong/old pdf.
Unread 11-01-2010, 17:38
FRC #0675
After testing the recommended code, I still have some problems.
I am using that with print statements between every line. The one before the first line makes it to the terminal, but after that there is nothing. Then after a while some cryptic errors pop up.
The one that leads me to believe this is a hardware problem of some sort is:
connect: S_errno_ETIMEOUT
As far as I can tell, that means I am done here. Unless anyone has any other ideas or hardware change recommendations.
-Luke
Unread 11-01-2010, 17:41
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
-Luke
That seems like it would indicate a problem instantiating an AxisCamera object....as to how to fix it, unfortunately no idea until I can get into a lab and play around a bit.
Unread 11-01-2010, 23:06
I assume you set up the camera passwords per the control system documentation?
Unread 12-01-2010, 13:55
FRC #0675
Ok, I feel like I am close to the solution. One thing I am seeing, after poking around in the console of the cRIO, is that it only has two network devices, the loopback, and the main one with the 10.xx.xx.2 ip. This makes me wonder how port two is supposed to connect on a different subnet to the camera.
My question then, is if one of you who has the console working to your cRIO could run "ifShow" and just tell me what things are listed. Failing that, I am at my wits end and I will have to call NI tomorrow if I cant get this fixed.
-Luke
Vision problems and FIRST members ebmonon36 Chit-Chat 10 21-01-2006 22:43
vision camera Adama Programming 3 19-01-2006 17:12
71's Vision Tracking Problems Bill Beatty Rumor Mill 7 19-04-2005 17:41
Camera Vision Range Muhnki Programming 7 05-02-2005 23:26
