Go to Post FIRST really truly is not about the robots, is it? - Barry Bonzack [more]
Unread 11-01-2010, 17:19
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Wheel encoder options.
I'm looking to see what's available for wheel speed encoders these days.
I know there is the KOP encoder that fits to the KOP gearbox, but we had bad experiences with that gearbox last year (gears grinding themselves to death).
I see that Banebots has an encoder that fits their P8 gearboxes, but (once again) those gearboxes are backordered.
I thought of using the new mag sensors as a tacho.
Any other options out there for rpm measurement (with quad encoder outputs) that have a reliable mounting mechanism?
Note: Our transmission will probably be direct drive, so there is no chain or belt to make use or an idler wheel.
Phil Malone
http://www.GEARSinc.org
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
Encoder wheel loose on shaft SuperBK Technical Discussion 1 17-01-2009 11:08
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Options! Brandon Martus Announcements 0 15-04-2002 13:08
