Go to Post If people played without PDA's back when FIRST had this addiction to nigh-impossible-to-calculate-in-your-head multipliers, then we can play without PDA's now. - Ian Curtis [more]
Unread 11-01-2010, 17:18
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question Potential Energy stored in a pneumatic ram
Our team (1566 The Ammoknights) is wondering if it is possible to "charge" a pneumatic ram. In other words, is there a way to store potential energy in a pneumatic ram and then release it very quickly?
Thanks,
Mitch Guzman
Team Captain Team #1566
be prepared for the unexpected
Unread 11-01-2010, 17:29
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: Potential Energy stored in a pneumatic ram
if you have an air tank between the valve and ram, and a mechanism to release the ram after it has been pressurized, you can get the cam to move quite fast.
I believe team 360 used this in combination with a large spring to launch the trackballs during Overdrive.
also, if you need speed, lower the diameter of your cylinder. it won't be as strong, but it will move much faster. if you add a weight on the end of the cylinder, the momentum will impart significant force.
[center]
Unread 11-01-2010, 17:31
Dan 1038's Avatar
Dan 1038 Dan 1038 is offline
Team Leader
AKA: Dan Stauft
FRC #4740 (Spartan Robotics)
Dan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond reputeDan 1038 has a reputation beyond repute
The easiest way I can think of is to use a stop to hold the actuator whilethe cylinder is charged, then release the stop to release it... just like you would do using a spring or similar power source.
Dan
2011-Present
Founder & Team Lead, FRC Team 4740 - Spartabots, Nashville, TN
Founder, FRC Team 3945 - Cobrotics, Whites Creek, TN
Mentor, FRC Team 4306 - Robo Komodos, Franklin, TN
2005-2011
Mentor, FRC Team 1038 - Thunderhawks, Liberty Township, OH
Unread 11-01-2010, 17:33
ZInventor's Avatar
AKA: Zeno Le Héricy
exactly, you just have to be extremely careful, as there are huge forces involved!
a 2 inch diameter cylinder pushes with close to 200 pounds of force at 60 PSI!
[center]
Unread 11-01-2010, 19:30
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
you can get a more instant oomph if you lock the piston at 1/3 extension b4 pressurizing and then releasing it. that way the gas can expand faster since it's already in the piston.
Note: this accomplishes the same thing as having a piston extension lock and a tank between the solenoid and piston... just a tad faster.
Can you play Crysis?
Unread 14-01-2010, 11:51
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
wow! thats a really cool idea. Im gonna try that out this weekend and see what we can do.
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 14-01-2010, 12:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Several teams used this concept in 2008 to launch the track ball. Also consider using an "over center" linkage design...so you don't need to use a lot of force to release it.
Unread 14-01-2010, 12:15
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
We did something simmilar in 2008, where our catapult was held down by a pneumatic latch. We then charged the cylinder powering the catapult with 60 psi, and when we wanted to fire, we essentialy pulled the pin. This worked quite well and we were able to fire the ball over the overpass easily.
Unread 14-01-2010, 13:24
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
How many times can the piston crash against its end before it hammers itself apart?
Bruce
Unread 14-01-2010, 13:51
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Bruce
Most cylinders have 'bumpers' within them to prevent damage when being fully actuated.
___________________
- Tennyson, Ulysses
Unread 14-01-2010, 13:54
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
How did you lock it in place? Did you use a piston to push a pin into the lock? Or did you just use the piston as the pin? If it was the latter, can you tell me what size your pistons were and how much damage was done to the smaller lock piston?
Unread 14-01-2010, 17:51
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
reversed_rocker is on a distinguished road
dont add weight to the end of the ram, remember, KE = (mv^2)/2
Unread 14-01-2010, 18:07
As a reminder to all teams and those that are reading this thread...
R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R40> for specifications and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
Unread 14-01-2010, 18:27
FRC #1360
I don't see why using a locking system and pneumatic cylinder breaks any of these rules at all.
Unread 14-01-2010, 19:54
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
It depends on how it is used. You could apply force to the rod of a pneumatic cylinder that had air trapped behind the piston by a closed valve. This could cause the air in the cylinder to exceed 60psi, which would be a rule violation. There are various ways to both do this sort of thing and prevent it, depending on what you are trying to accomplish
Christopher H Husmann, PE
"Who is John Galt?"
[OCCRA]: vex stored energy bernieseaholm OCCRA Q&A 1 12-11-2008 16:44
Pneumatic Ram Question Magnechu Pneumatics 14 23-01-2008 16:42
Stored Energy Devices? K.Porter Technical Discussion 6 07-01-2008 13:59
Maximum amount of stored energy? pryoplasm Technical Discussion 1 19-01-2004 20:57
Adding RAM to RC archiver 2001 1 24-06-2002 00:59
