Go to Post I shouldn't be doing a happy dance or anything, should I? - Qbranch [more]
Unread 11-01-2010, 18:25
Aaron S's Avatar
Aaron S Aaron S is offline
FRC #1612 (Robosharks)
Aaron S is an unknown quantity at this point
Send a message via AIM to Aaron S
Re: Windriver - Cannot Create New Example Project
Everything is defaulted. The install directory is C:\Windriver, and the workspace is C:\Windriver\Workspace (notice the capitalized W's). Last year I installed all of this the same way in a virtual machine on my Mac OS X partition and it worked fine, so I'm not sure what the deal is.
Unread 14-01-2010, 03:29
Aaron S's Avatar
Can anyone offer any advice? I can't get started programming until this issue is fixed.
Unread 14-01-2010, 14:54
AKA: Brad
#0190 ( Gompei and the Herd)
Are you running on a mac now? is this with Parallels or VMWare?
Brad Miller
Robotics Resource Center
Unread 14-01-2010, 17:15
Aaron S's Avatar
No, this error is popping up under Windows XP while running natively on a separate partition.
Unread 19-01-2010, 21:25
AKA: Brad
Aaron -
Have you been able to get this working?
Brad Miller
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 25-02-2009 01:58
help:Downloading the project in windriver mahmosh C/C++ 5 10-01-2009 10:08
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Arizona gets half million to create new teams! falconmaster General Forum 20 04-11-2007 23:00
Can anyone create new commands? Jakenan Programming 5 22-01-2005 21:38
