Thread Tools |
Rating:
Display Modes |
Re: Tank Treads
I think tank treads would be pretty epic. Kudos to the teams who use them.
Re: Tank Treads
The only problems with tanks would be getting over the humps if the treads aren't set up right....
Re: Tank Treads
Ya we think its a gamble but if it pays off it should help us a lot going over the humps hope it works >_< *crosses fingers*
Re: Tank Treads
How about a half track?
Re: Tank Treads
You would need to do some rather extensive thinking about the suspension. Our team is kicking this idea around and my hint is to go look at the mechanical structures of military tanks. Any other comments about tank treads and teams that are planning to use them are highly appreciated.
Re: Tank Treads
#7
Re: Tank Treads
#8
Re: Tank Treads
We were considering that, but in the end we decided to go with a whole tread. I forget the reasoning, however. But even so, it would still not change the question of where to get some treads for a reasonable price
#9
Re: Tank Treads
#10
Re: Tank Treads
As Andrew said we did consider it but then we decided not to because we think that the tracks will help us navigate the humps easier
As of now we were thinking about maybe adapting snowblower tracks to suit our needs |
#11
Re: Tank Treads
Me and Bill were discussing finding synchronous conveyor belts, but they were rather expensive, like $400 a piece.
#12
Re: Tank Treads
You could try http://www.andymark.biz/am-0566.html or http://www.andymark.biz/am-0565.html for some belting material. AndyMark also sells 1" wide x 10' long pieces, officially for use on a plaction wheel. Nothing says you can't put some 1" wide pieces of different types side-by-side to get a tread. You'd still have to figure out how to connect the ends, though.
#13
Re: Tank Treads
Thank you, EricH, that might work well! It's cheap too! Just have to figure out how to rig it to work....
#14
Re: Tank Treads
Re: Tank Treads
I would recommend Brecoflex for the final design but for prototyping, inverted and double sided timing belt is an appropriate substitute as the pulleys (wheel?) for Brecoflex would take time to order and ship.
| Tank Treads? | reversed_rocker | General Forum | 7 | 20-04-2009 19:10 |
| Tank Treads??? | SLA | Kit & Additional Hardware | 2 | 16-01-2007 20:53 |
| Semi-Tank Tread/Half Tank Treads | thoughtful | Technical Discussion | 4 | 11-01-2005 08:33 |
| Tank Treads | dddriveman | Kit & Additional Hardware | 27 | 06-05-2004 18:16 |
| Tank treads | snowdragon | General Forum | 0 | 21-01-2004 16:57 |
