Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
Unread 11-01-2010, 17:31
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Staying in Zones
INVALUABLE TOPIC! Thank you guys for your ideas!
Speaking of balls as currently available balls in the field, I agree entirly that the center is an important zone after the moment when the first 6 "safe balls" (the 6 balls that in the beginning of the match that are set up by the alliance's decision, and could be said to be "controlled" by their own alliance. These balls have a high probability of getting scored for sure at the first seconds of the match, tele and auto). The fight over the control of the balls will exist. Middle bot will always want to keep a fresh supply of available balls for scoring in the near zone for the Near bot. But if a "battle of control" occurs between the two Middle bots for trying to send the returned balls to thier own alliance's Near bot, Both the Defending (Far) bot and Scroing (Near) bot will be idle for a while, if they maintain thier role the whole time. These robots should have the ability to manuver across the ramps (that includes the option of going through the tunnel), in order to assist the bots in the battle.
This could say something about Middle bots. They will be moving most of thier time only inside thier own zone. So if you would like to have the best Middle bot in your alliance, I personally would chose that bot that could push other robots effectivly, manuver extermly quick and be able to pass balls to the Near/Far zones fast and effectivly.
Battles for control, if are given assistance from the other zone bots, will eventually cieze after a couple of seconds after the arrival of the assisting bots, for the moment a bot posses a ball, or has been able to pass a ball or two to the desired zone, the Scorer bot should return to score.
Wow, this is getting much more specific....
But I think FIRST finally did it. We finally have a game where teamwork and coordination between the teams in the alliance is PARAMOUNT for any kind of victory in the game. I like that....
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 11-01-2010, 17:43
Passion Passion is offline
Jim Zhou
FRC #2198
Passion has a spectacular aura aboutPassion has a spectacular aura aboutPassion has a spectacular aura about
This game is expected to be played out very similar to a soccer match. Each robot has a unique role. If you are at far end zone, you HAVE TO play at least some sort of defense and passing the ball to the midfielder.
Let me put it this way, how would you not be tempted to block the opponent from scoring when you are right beside their goal post?!
A defensive robot should be able to catch the opponent's soccer ball, and output it to the midfielder.
There are two goal posts, if you are the only one playing defense on your team, that means only ONE goal post will be covered, and leading another goal post open to be scored.
A very effective defense strategy is building a robot that is efficient at controlling the movement of the ball and outputting/passing it. Reason being is that the defensive robot should go to midfield where the soccer balls are dropped. If your robot collects the balls faster and passes them to teammates to score faster than the opponents do, where would the opponent bots get the soccer balls to score?!
The best way to defend is to take away the opponent's scoring balls!
Unread 11-01-2010, 18:18
Jonanin Jonanin is offline
AKA: Jon Morton
FRC #1306 (BadgerBOTS)
Jonanin is infamous around these parts
Send a message via AIM to Jonanin Send a message via MSN to Jonanin
I think that many of you guys that are talking about how it's important to support less effective/broken robots and the like are forgetting that the alliance gets to choose where the robots start. The fact that the alliance gets to plan ahead removes a lot of those problems, at least in my opinion
Obviously, there will be some situations in which moving to another zone is advantageous. However, does this REALLY outweigh the added complexity of designing a really short robot or a robot which can successfully navigate over the bumps? Not doing this allows you to REALLY focus on your robot's strengths, such as a very amazing kicker.
Unread 11-01-2010, 19:44
Sammy G Sammy G is offline
Team Leader/Fundraiser
AKA: Mason
FRC #0568 (Nerds of the North)
Sammy G has a spectacular aura aboutSammy G has a spectacular aura about
Send a message via MSN to Sammy G
Has anyone considered the importance of the end of the game? To even attempt to get points for suspending and lifting robots. The bot placed in the far side would have to be able to travel over the bumps.
Or is the ablilty to climb up not considered as important this year? It seems to me that the end game will be important to deciding the winning alliance. Maybe I am underestimating the ability of the offensive robots to score.
"What do you mean, 'These robots do not fight each other'?!? What else do people use them for?!"
http://www.dimondrobotics.com/
FRC 568: Nerds of the North
Unread 11-01-2010, 19:53
My take is that no matter where you are at the start, or where you plan to stay, you should have the ability to change zones due to the well-known fact that plans change suddenly when you have opponents. How you change zones is up to you.
Unread 11-01-2010, 21:41
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
I'm not certain why you would want to play defense in this game at all (at least in qualifiers). My thought was move the middle robot to the front zone (two scorers) and the far robot to the middle zone (ball handler), and then all three are in position to score huge points and hang. This will produce the highest match scores and seeding scores. In my opinion its dangerous (potential penalty) and a waste of time to try and get the balls from the far field to the near field...
If another alliance does this and tries to score, you can only have 1 defender for two scorers with two goals... In hearing what one of the GDC guys had to say, I think this is what the expect to happen... and is ultimately the "smart move" for seeding points.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 11-01-2010, 21:48
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
I think that the fight will be in the middle. It's up to you to "Breakaway" and score.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 11-01-2010, 21:56
Jim Zhou
FRC #2198
In your particular scenario, the defensive robot would have to go to the midfield where soccer balls are being dropped after being scored from both teams. The robot would have to stay in that position right after where the balls are dropped, and then try to take away as many soccer balls before the opponent can get it as possible to minimize the chance of the opponent bots getting the soccer balls.
How would the opponents score if they are unable to get a soccer ball? My point is to take away their source of soccer ball.
Unread 11-01-2010, 22:24
run the trap!!!
Team Role: Human Player
Originally Posted by Jonanin View Post
I've been thinking about game strategy for quite a while now, and I am becoming increasingly convinced that it will be useless and possibly even detrimental for robots to move away into different zones than their starting ones. It just doesn't seem like it's worth all the extra trouble. As such, it seems as though being able to effectively pass will be a big one.
All three zones are equally important in my eyes. The one closest to the goal is for scoring easily, the one in the middle is for retrieving and passing forward scored balls that return, and the far zone is for stealing balls and passing forward the opponents missed/stray balls. Since all of these zones require attention, what's the point of leaving one? You are just creating a disadvantage for yourself as you are lettings your opponents robots have free reign over a zone. I think the balls will be relatively equally spread out between zones, despite the fact that they only return to the middle. After all, the goals aren't in the middle are they? Why would the balls be concentrated there of all places?
Is anyone else thinking some of the same things as me?
Yes, that is a great strategy and will probably win several (if not many) regionals.
But what about qualifications? If you're the only bot on your alliance with ball handling skills you will be needed in all three zones.
You may even need to move balls from the middle to your side and then score them yourself. A slow painful strategy... but it may be your only option.
-Philip J. Fry
Unread 11-01-2010, 22:32
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
Originally Posted by scottydoh View Post
I agree completely, except im out numbered 20 to 1 at our design meetings. Im trying to convince my team that crossing the border should only be used as a last resort in extreme situations. I feel its just to dangerous and will take far to long for the little assistance it might provide.
Same situation and I agree completely. Best to stay in one zone except for maybe one robot to move between it's alliances zone and midfield. But the other two shouldn't need to be worrying as much about it.
2011 Peachtree Regional Dean's List Recipient
2011 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2011 Lemelson/MIT InvenTeams Grant
2010 North Carolina Regional Chairmans Award
2010 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2010 SeaWorld Busch Gardens Environmental Excellence Award
2009 Peachtree Regional Chairmans Award
2008 Peachtree Regional Judges Award
Unread 11-01-2010, 23:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Granted, that quals may be a little tough. But this is always the case. It doesn't make sense for most teams to decide they need to do EVERYTHING on the field because they might get some bad seeding matchups. Teams should consider the importance of doing everything vs the likelihood they'll be able to do everything.
Unread 12-01-2010, 00:21
jesse.elite's Avatar
jesse.elite jesse.elite is offline
President
FRC #0948 (Newport Robotics Group (NRG))
jesse.elite is an unknown quantity at this point
The ideal robot here would be one that can do one task really well (shooting, blocking, passing, etc.) but also be able to have flexibility. But the specialty part is important. However, I can foresee robots changing zones only when they need to help an ally flip over. If aliances do their jobs right, there won't be a need to change zones to get balls.
Unread 12-01-2010, 06:34
Chris is me's Avatar
AKA: Pinecone
For what it's worth, depending on how wrong I am on strategy... if it were up to me, I would personally not pick more than one partner completely incapable of moving between zones, and only one in an exceptional case. Guess good thing it's not.
Unread 12-01-2010, 10:54
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Where is the most points? Three robots spending 15-20 seconds hanging off each other and the rack or spend the time socring more balls from the zones they are in.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 12-01-2010, 10:55
AKA: Pinecone
If you can score 2/3rds of the balls in the entire game in 20 seconds, be my guest.
<G29> Robots in opposing zones. gorrilla Rules/Strategy 25 10-01-2010 13:16
Dead Zones CronosPrime1 Programming 8 02-02-2006 22:19
Automated Loading Zones? Deltafrog Rules/Strategy 24 09-01-2005 12:31
Devices that go to the home zones Perseus General Forum 2 13-03-2002 12:55
Terminology of zones Mike Soukup General Forum 6 29-01-2002 23:35
