Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 11-01-2010, 22:09
w84me w84me is offline
FRC #2832
w84me is an unknown quantity at this point
Can we use a different camera?
Is it possible to use a different camera and still get the same results as the one FIRST provided us with?
Unread 12-01-2010, 06:56
Re: Can we use a different camera?
Possibly. One part of the question is whether it is legal to use another camera. I believe that will need clarification from GDC. Technically, some/most Axis cameras will work with the drivers in WPILib, and other IP cameras will work with slightly modified drivers.
Greg McKaskle
Unread 13-01-2010, 22:55
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Greg McKaskle
I hope that the answer is that other cameras are allowed. The Axis 206 camera has been replaced by the 207. You can still find the 206 for sale some places, but will eventually disappear.
The Axis cameras are expensive, for what they are, as well. Dlink has some interesting cameras for 1/3 the price. I don't know if the will work with our software, or not, though.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 14-01-2010, 13:00
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
All cheap cameras are not created equal. We tested the D-Link cameras 2 years ago. We recommended the Axis because it's color accuracy was way better, the latency on the image was way lower (hardware JPEG compression), it boots faster, it's smaller, etc. All around, it was easily worth the difference in cost. If you think it's hard to make a vision system work reliably with what we use now, you'll be in a whole new world of hurt if you go for even worse cameras.
D-Link may have released new models since then that are a departure from their earlier performance, but I wouldn't move ahead without validating it thoroughly.
Can we use the camera image on Dashboard this year? Jon236 Programming 1 11-01-2010 12:52
DIfferent Year CIMS run at materially different speeds ? de_ Motors 5 19-02-2009 13:04
Using different Camera Servos 3dude_2231 Motors 6 19-02-2007 14:01
Can not use camera code!!:'( teh_pwnerer795 Programming 2 14-12-2006 10:06
can we use? Allie Kit & Additional Hardware 5 13-02-2002 15:54
