Go to Post FIRST games are complex and rely on design and intellectual capability much more than the average sport. - Chris is me [more]
Unread 11-01-2010, 22:11
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
PID Control
I'm new to PID controlling, and am looking to learn. Anyone have a suggestion as to where to start?
As far as I understand, it seems as if a PID is to verify that a variable is actually where it's supposed to be by checking, such as rotational velocity with a motor and an encoder or angle with a drivetrain and a gyro, etc. Is that right?
Unread 11-01-2010, 22:16
Re: PID Control
Not PID but very useful for controls for autonomous mode.
http://www.wildstang.org/main/stangps.php
Unread 11-01-2010, 22:24
FRC #0107
Re: PID Control
Unless I missed something, I don't think I saw anything about PID in that presentation. Very informative though.
Unread 11-01-2010, 22:38
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Re: PID Control
Wikipedia has a rather helpful article on the subject. Even has some pseudo-code to look over:
previous_error = 0
integral = 0
start:
  error = setpoint - actual_position
  integral = integral + (error*dt)
  derivative = (error - previous_error)/dt
  output = (Kp*error) + (Ki*integral) + (Kd*derivative)
  previous_error = error
  wait(dt)
  goto start
Unread 11-01-2010, 22:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: PID Control
PID stands for Proportional-Integral-Derivative
Each is a "term" and the result of each is added to get the motor motion or change.
Proportional is, well, proportional to the difference between where you are and where you want to be. Basically, you say error = want - at, and then multiply that by a constant that testing reveals to be correct (the highest number without too much overshoot). Integral is the integration (sum) of the already corrected error, and gives the offset that should have been previously corrected.Derivative adjusts the rate of change by determining the slope of the error, the rate of change. This helps to even out noise.
Each term is multiplied by a gain that is statically set and manually tuned - this determines how much affect each term will have on the final output. It is also possible to switch from several gains based on set conditions, for example if you have a multi-jointed arm you might change the gain of the shoulder based on how far out the end-effector is from the shoulder, to prevent tippage when far out but allow it to move fast when tucked in.
PID is used in closed-loop control, basically you set a setpoint and it actively works to achieve it. This can implement itself in various ways, such as checking the angle of a potentiometer and adjusting it with a motor (used for angle control), checking the speed of a motor using an encoder and making it correct (useful for shooter wheels or such that must run at a certain speed), or even during autonomous to get the accumulated angle of a gyro and turn the chassis to acheve the desired angle, or setting the distance to travel and actively trying to get there without overshoot.
The standard FRC LabVIEW installation includes a PID toolkit - that can help. All you need to do is set the gain of each term.
If you want to learn how to do I would recommend implementing the simple Proportional control, tuning it, and seeing how it works. If you have problems, add either I or D depending on the problem. If you still have problems, add the other one.
One very very important thing to remember when working with potentiometers - if you turn them past their limit, they will break. Make sure that a positive motor direction = positive change in voltage. If this is not so, multiply the output by -1 or swap the wires on the OUTPUT side of the speed controller or the motor input. You could also swap the RED and BLACK wires on the pot.
As for where to start....
If you have large articulating structures on your robot, the most useful would be to use a potentiometer and a motor to control the angle. This would allow you to baically have a giant servo.
If you want to do autonomous stuff, then try to control the rotation (X on an arcade drive) using a gyro and a desired angle. When you get close to the desired angle, it will automatically slow down as the gain decreases and you will have a perfect turn.
And one last tip:
Always limit the output to -1 to 1. This is the range of the output and it is always good practice to do so. Do not rely on the WPIlib to do it for you.
And wikipedia has an article on the subject.
Kettering Motorsports
Unread 11-01-2010, 22:48
Best Available Data
FRC #1778 (Chill Out!)
Re: PID Control
Matt Krass' White Paper on PID Control Theory
I'm no software guy, but I understood it once I finished that paper.
Unread 11-01-2010, 22:49
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: PID Control
I made a spreadsheet to model an ideal PID system. Its useful for understanding some of the basics, and how changing the parameters affects the output of the system.
http://www.virtualroadside.com/blog/...n-spreadsheet/
Unread 11-01-2010, 22:51
goodsky's Avatar
goodsky goodsky is offline
Programming Mentor
AKA: Skyler
FRC #1902 (Exploding Bacon)
goodsky has a spectacular aura aboutgoodsky has a spectacular aura aboutgoodsky has a spectacular aura about
Re: PID Control
I agree the Wikipedia is very helpful on the subject, and if you want even easier to read guides all I did was google "simple PID"
Also often I find that a PD or just a P loop will work for many simple actions. So starting with those to determine if you need the added complexity of a full PID is a good place to start.
OINK OINK BOOM!!!
Unread 11-01-2010, 22:56
FRC #0107
Re: PID Control
awesome, I'll take a look at all of those. I haven't looked myself, but does the WPILibJ (that is, Java) include code for PIDs?
Unread 12-01-2010, 00:16
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: PID Control
Well, I know there's a PID toolkit provided with the FRC LabVIEW software.
However, there's a bit about it I don't understand.
I'm used to dealing with Proportional gain, Integral gain, and Derivative gain.
With the NI functions, the inputs are Proportional gain, Integral time, and Derivative time.
What are Integral time and Derivative time, and why would those be used as constants instead of the gain being used as constants?
-- Marshal Horn
Unread 12-01-2010, 01:15
Re: PID Control
Have you read the PID Control Toolkit User Manual?
Unread 12-01-2010, 07:33
Re: PID Control
As Joe said, they are convertible. Kp equals Kc, Ki equals Kc/Ti, and Kd equals KcTd.
If you understood that without the manual, you are amazing.
Greg McKaskle
Unread 12-01-2010, 11:07
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: PID Control
This is how I learned PID as well. Just note that the source code in it is a bit out of date. It's from back in the days when we wrote in C, and PWM outputs were unsigned char values instead of wonderful floats.
Unread 12-01-2010, 15:10
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: PID Control
I have not used it, but WPILib (and presumably J and LV too) has a few Pid classes, so you shouln't have to completely write a PID loop
Watchdog.Kill();
Unread 12-01-2010, 20:39
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Re: PID Control
Last year I was on 2343 (back in the USA) and was the lead on Autonomous. We used a PID loop, and in 6 weeks I went from knowing nothing about them, to programming one. I used the WPIlib documentation, as well as FIRST wiki, and the experience of my mentors. Between those three sources, I got a good understanding how the PID class works.
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
PID traction Control dpeterson3 C/C++ 5 26-01-2009 21:11
PID Control John Gutmann Programming 12 15-04-2007 18:52
Generic PID control code Uberbots Programming 3 26-02-2007 16:59
PID Control Chris Bright Programming 9 26-03-2005 19:44
PID Control Loops ttedrow Programming 7 05-12-2002 12:03
