Call up Pro/E files in SolidWorks
As a SolidWorks CAD designer, I want to remind (inform) people that most of the part files available for Pro/E will open in SolidWorks just fine. No need to spend time creating most of the 3D parts.
Just download the Pro/E files (from FIRST's site) to your computer, open SolidWorks, and do a file open and ensure it is looking for *.* Then you will see all of the Pro/E files. It will do a quick file conversion. It will ask for features or body. Features is more robust but usually not needed. I suggest "body" unless you plan on changing a CAD file. For purchased, off the shelf, parts we usually have no need to change dimensions. Troy Mentor--SolidWorks user since 2003--CSWA |
Re: Call up Pro/E files in SolidWorks
These imported parts may or may not come in with materials.
You can set materials by right-click on the Materials tab in the FeatureManager. You can also set the exact weight in Tools, MassProperties. Watch out for little descrepencies with imported geometery, when I imported the AM0204, and set material to Al 5052 I got 1.2 pounds but Andy Mark states it is 1.4. Use a scale for the exact weight. On thing nice about imported geometry, it makes your assembly model very light weight. Saves time. Dont spend your time recreating purchased kit parts - you have an arm to design! Marie |
| Solidworks KOP files | nittemare | SolidWorks | 7 | 15-01-2012 18:00 |
| Is it possible too import the Auodesk Files to Solidworks? | vmuralidharan | Inventor | 2 | 10-01-2009 14:41 |
| Solidworks to Pro/E file conversion | Peter Matteson | SolidWorks | 1 | 04-08-2006 14:07 |
| Inventor / solidworks / Pro E | Andrew Schuetze | Inventor | 11 | 19-06-2006 10:27 |
| Solidworks Files | Panther378 | Technical Discussion | 1 | 21-01-2006 22:34 |
