Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
  #31   Spotlight this post!
Unread 11-01-2010, 22:22
Ram Raman Ram Raman is offline
FRC #2876 (BhsRobotix)
Ram Raman is an unknown quantity at this point
Send a message via AIM to Ram Raman
Re: Effective Drive Base
Would four wheel drive be effective, would it be able to make it over the bumps, how would the turning be?
  #32   Spotlight this post!
Unread 11-01-2010, 22:45
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
can someone explain to me how the serve/crab drive will not be an effective climber? I don't understand how the fact that a swerve is complected would matter when climbing. Climbing is all about traction and a swerve with the right wheels would have the same traction as other systems.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
  #33   Spotlight this post!
Unread 11-01-2010, 23:03
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
It depends on how you build it. If you make a typical swerve with small wheels, then have fun going through the tunnel. But if you use larger wheels and put them directly in the corner of your robot without any frame to inhibit contact between the wheels and bumps, then I would say that you have a very good chance of getting over the bumps.
Mecanum would seem like a very poor choice this year, especially with such a small area to get through the tunnel. But some will do it and someone will do a great job with it. There always is at least one good team with mecanum!
1058 PVC Pirates 2016 - xxxx
  #34   Spotlight this post!
Unread 11-01-2010, 23:12
The kit bot rolls over the bump with ease because of the large wheels, it does not bottom out on the top of the bump. However, turning with 4wd is a pain. The robot "jumps" as it counters the friction while turning with skid steer.
  #35   Spotlight this post!
Unread 11-01-2010, 23:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Nathan2974 View Post
I just wanted to point out that the actual grade of the bump is approximately 38.7 degrees (or something to that effect) using simple trigonometry based on the height and width provided by FIRST.
Sir, you should perhaps examine the official field drawings for the bumps that will be on the field. The chamfer on the rib that supports the bump happens to be 10 1/4 high and 10 1/4 wide. Simple trigonometry tells me that the bumps FIRST is going to be building will be at an angle of 45 degrees.
  #36   Spotlight this post!
Unread 11-01-2010, 23:28
Originally Posted by Madison View Post
For the sake of discussion, I'm attaching a picture that shows an 8WD system going over the bump.
Madison,
You should put a CG marker on your sims, things get more interesting when you start looking at where your robot starts tipping, and where you end up after you tip.
  #37   Spotlight this post!
Unread 11-01-2010, 23:56
dtengineering's Avatar
AKA: Jason Brett
Thanks, Kevin... before I read your post I was thinking... "NOOoooo... we didn't screw up when we built 45 degree angle bumps... did we?", and actually went and re-downloaded the drawings to check.
I've attached the relevant image here.
45 degrees is correct... and wow... it sure looks scarier in person when you see an actual bump first hand than it does when you look at the drawings.
On a seperate note, a student drew up some drawings very much like Madison's this afternoon... and while I don't think ground clearance will be an issue, so long as teams plan for it, CoG is certainly going to be.
After watching teams like 254 climb the ramp, drive sideways across the ramp, basically jump off the ramp and show off what a low CoG can do in Aim High, however, I'm pretty convinced that we can build an even lower CoG for this game. In fact, I wouldn't be surprised if some of those old Aim High robots have already made it over the bump....
I think the really maneuverable robots this year will not only be able to "get air" off the ramp, but to climb a flight of stairs.
Jason
Edit: And as for making a 4wd robot with big wheels turn... AndyMark might be able to help out a bit http://www.andymark.biz/am-0104.html
Name:	ge-10047-03 bump rib.jpg
  #38   Spotlight this post!
Unread 12-01-2010, 01:16
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Madison's 8wd picture is looking pretty good...and similar to what we came up with when comparing 6 and 8 wd bots going over the bump.
You can get the CG way lower with 8wd than you can with a 4wd bot that clears the bumps. And playing with raised end wheels does neat things to steering ability.
  #39   Spotlight this post!
Unread 12-01-2010, 01:25
run the trap!!!
Team Role: Human Player
Actually, the kitbot does not roll over the bump with "ease". The tough-boxes bottom out on the top of the bump, and unless you are moving with speed you will get stuck there.
I’ve confirmed this both in CAD and testing.
Of course you can mount the T-boxes on top of the frame, and solve this problem.
Interesting design feature AM...
-Philip J. Fry
  #40   Spotlight this post!
Unread 12-01-2010, 01:28
That's how we have them set up. I figured teams would have figured that out when trying out the kit base. Also, the kit base's "slick wheels" help a bit with turning the 4wd.
We are most likely going with 8 with the front sets raised slightly, I think it will be a common design among experienced teams.
  #41   Spotlight this post!
Unread 12-01-2010, 01:51
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Madison,
Given that my model is symmetrical in two planes, the CG is right in the middle. The robot will obviously behave differently going over the bump if the CG is very far forward or aft, but my model isn't complete enough to capture that yet.
8WD may send the robot "higher" on its way up the bump, but the same behavior that causes that also prevents the end of the robot from falling quite as far as it might on a 6WD system. I am under no illusion that the robot will ever stop successfully on the flat top of the bump and understand that it's going to dive hard into the ground on its way down in all cases, though.
It's also possible to implement 6 or 8WD systems wherein the wheels are not equidistant from one another and see some altered behavior from that. In 8WD, moving the center wheels closer makes the system begin to approximate a 6WD frame -- so it won't ride up as high while climbing, but falls correspondingly further on the trip down. It's all about trade offs, obviously, but I am more concerned with minimizing the force of the giant thud that'll happen on the way down than I am with tipping to 45* on the way up.
--Madison--
...down at the Ozdust!
  #42   Spotlight this post!
Unread 12-01-2010, 03:31
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Half-tracks, anyone? Short tank treads in the back, powered omnis up front. Power to push & climb with the addition of maneuverability...
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #43   Spotlight this post!
Unread 12-01-2010, 07:34
Try mounting the transmissions on top of the chassis.
  #44   Spotlight this post!
Unread 12-01-2010, 09:59
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Could 4 wheel crab steering make it over the bump?
Our team is looking into either that or standard 4 wheel skid steering.
  #45   Spotlight this post!
Unread 12-01-2010, 10:08
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I would love to see a version of 2004-71 style swerve.
Hi!
pic: drive base idea dbell Extra Discussion 23 26-07-2008 11:11
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
Drive Base Advice archiver 2001 0 23-06-2002 22:57
