Go to Post I have to wrap my brain about a robotics team named Dudettes. I can get there but ... I need coffee. - JaneYoung [more]
Unread 11-01-2010, 00:53
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Can't run BuiltInDefaultCode out of the box?
Hello!
I just got my cRIO talking to NetBeans, Cool!
I created the project BuiltInDefaultCode from the sample file, and simply hit Run!
It connects, but errors out. Here is the log:
clean:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\build
Compiling 1 source file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\build
compile:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\j2meclasses
preverify:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite
Building jar: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite\BuiltInDefaultCode_1.0.0.jar
jar-app:
Using "suite\BuiltInDefaultCode_1.0.0.jar"
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Romizer processed 73 classes and generated these files:
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.sym
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite.metadata
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite.api
Expanding: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite\BuiltInDefaultCode_1.0.0.jar into C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite
Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite
Deleting: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite.api
Connecting FTP @10.31.83.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Setting up for RUN
[cRIO]
   Waiting for prompt "-> "
[cRIO] ->
[cRIO] -> xdelete "/ni-rt/system/SQUAWK_DEBUG_ENABLED"
[cRIO] deleting file /ni-rt/system/SQUAWK_DEBUG_ENABLED
[cRIO] /ni-rt/system/SQUAWK_DEBUG_ENABLED: S_relFsLib_FILE_NOT_FOUND
[cRIO] value = -1 = 0xffffffff
[cRIO] ->
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
   Waiting for cRIO to reboot (8s)
[cRIO] ->
[cRIO] -> * Loading StartupDlls: debug
[cRIO] Entering debug.o StartupLibraryInit
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO] Copyright 1984-2006  Wind River Systems, Inc.
[cRIO]
[cRIO]              CPU: MPC5200 -- Wind River Lite5200 BSP.
[cRIO]     Runtime Name: VxWorks
[cRIO]  Runtime Version: 6.3
[cRIO]      BSP version: 2.0/10
[cRIO]          Created: Jul 29 2009, 13:41:47
[cRIO] ED&R Policy Mode: Deployed
[cRIO]    WDB Comm Type: WDB_COMM_END
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] Leaving debug.o StartupLibraryInit
[cRIO] * Loading StartupDlls: NiRioRpc
[cRIO] * Loading StartupDlls: niorbs
[cRIO] * Loading StartupDlls: NiViSrvr
[cRIO] * Loading StartupDlls: nivissvc
[cRIO] task 0xee3a28 (PAL00fb4dc8) deleted: errno=0 (0) status=0 (0)
[cRIO] NI-RIO Server 3.2 started successfully.
[cRIO] task 0xc5ee78 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading StartupDlls: nivision
[cRIO] * Loading StartupDlls: niserial
[cRIO] * Loading StartupDlls: FRC_FPGA
[cRIO] * Loading StartupDlls: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication was compiled from SVN revision 2064
[cRIO] FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
[cRIO] FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
[cRIO] FPGA Hardware Version: 2010
[cRIO] FPGA Software Version: 2010
[cRIO] FPGA Hardware Revision: 1.3.0
[cRIO] FPGA Software Revision: 1.3.0
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2010 FRC, Dec 30 2009, 15:22:08
[cRIO]
[cRIO] [OTA Server] Starting...
[cRIO]
[cRIO] [OTA Command Server] In serverSocketListener()
[cRIO]
[cRIO] [OTA Redirector] In serverSocketListener()
[cRIO]
[cRIO] task 0x215a4c0 (t2) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f2
[cRIO]
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe62050 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
[cRIO] [OTA Server] Restarting Java VM
[cRIO]
[cRIO] [Squawk VM] Starting up...
[cRIO]
[cRIO]
[cRIO] [Squawk VM] Version: 2010 FRC, Jan  9 2010, 12:44:17
[cRIO]
[cRIO] [Squawk VM] File SQUAWK_DEBUG_ENABLED not found, starting squawk in normal mode...
[cRIO] [Squawk VM]    arg: squawk.out
[cRIO] [Squawk VM] Squawk command line file SQUAWK_CMD_LINE not found, using default args...
[cRIO] [Squawk VM]    arg: -suite:robot
[cRIO] [Squawk VM]    arg: -Xmxnvm:1M
[cRIO] Bootstrap suite loaded
[cRIO] In Startup
[cRIO] Looking for implementation class com.sun.squawk.platform.posix.vxworks.natives.SelectImpl
[cRIO] Looking for implementation class com.sun.squawk.platform.posix.vxworks.natives.LibCImpl
[cRIO] com.ni.rio.NiRioStatus$FatalStatusException: Fatal status code detected:  -63195
[cRIO]     at java.lang.Throwable.<init>(88)
[cRIO]     at java.lang.Throwable.<init>(102)
[cRIO]     at java.lang.Exception.<init>(53)
[cRIO]     at java.lang.RuntimeException.<init>(58)
[cRIO]     at java.lang.IllegalStateException.<init>(56)
[cRIO]     at com.ni.rio.NiRioStatus$FatalStatusException.<init>(NiRioStatus.java:21)
[cRIO]     at com.ni.rio.NiRioStatus.assertNonfatal(NiRioStatus.java:325)
[cRIO]     at com.ni.rio.NiRioSrv.peek32(NiRioSrv.java:389)
[cRIO]     at edu.wpi.first.wpilibj.fpga.tGlobal.readLocalTime(tGlobal.java:57)
[cRIO]     at edu.wpi.first.wpilibj.Utility.getFPGATime(Utility.java:47)
[cRIO]     at edu.wpi.first.wpilibj.Timer.getUsClock(Timer.java:51)
[cRIO]     at edu.wpi.first.wpilibj.defaultCode.DefaultRobot.<clinit>(DefaultRobot.java:179)
[cRIO]     in virtual method #109 of com.sun.squawk.Klass(bci=49)
[cRIO]     in virtual method #106 of com.sun.squawk.Klass(bci=328)
[cRIO]     in virtual method #105 of com.sun.squawk.Klass(bci=32)
[cRIO]     in static method #2 of com.sun.squawk.Klass(bci=234)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(92)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1554)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO] Uncaught exception in Thread.run():
[cRIO]     on thread edu.wpi.first.wpilibj.defaultCode.DefaultRobot - main
[cRIO] java.lang.Error: ExceptionInInitializer: edu.wpi.first.wpilibj.defaultCode.DefaultRobot:com.ni.rio.NiRioStatus$FatalStatusException: Fatal status code detected:  -63195
[cRIO]     at java.lang.Error.<init>(57)
[cRIO]     in virtual method #106 of com.sun.squawk.Klass(bci=409)
[cRIO]
[cRIO]
[cRIO] --------------------------------------------------------------------
[cRIO] GCs: 1 full, 0 partial
[cRIO] ** VM stopped: exit code = 1 **
[cRIO] task 0x2159ec0 (SquawkRobotTask) deleted: errno=0 (0) status=1 (0x1)
Any ideas?
Unread 11-01-2010, 01:01
AKA: Jacob Komar
Re: Can't run BuiltInDefaultCode out of the box?
P.S. I just tried the EnhancedIO (something like that) and it runs fine
Just wondering what the problem with that original sample file is
Unread 11-01-2010, 11:14
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Not sure what the enhanced IO has to do with this? Did you try a different program and it ran ok?
As for the error you got, I think Brad will be best equiped to answer that. Lets see what he says.
Unread 11-01-2010, 13:15
AKA: Jacob Komar
Sorry I didn't make myself clear. EnhancedIOSomethingorother is the name of one of the other sample programs, which runs fine. I can't remember the name of it exactly.
Just wanted to bring this to Brad/The WPIlib team's attention.
Jacob
Unread 11-01-2010, 23:56
Daniel Jones Daniel Jones is offline
AKA: Hanes
FRC #0190 (Gompei and the HERD)
Daniel Jones is on a distinguished road
Thanks finding this, it was an issue on our end and should be fixed in the NetBeans update that I just posted.
"there are 10 types of people in this world, those who understand binary and those who don't"
Unread 14-01-2010, 15:32
a kenny03 a kenny03 is offline
Robotics for life(stupid classmate)
AKA: PICKELL!!!
FRC #0219 (Team Impact)
a kenny03 is an unknown quantity at this point
Send a message via AIM to a kenny03
Jacob
where exactly did you find this??? like an exact path.
i have been trying to do a benchtop test in java for almost 3 days now, and i can't get code to go onto the robot!
Unread 14-01-2010, 16:34
AKA: Jacob Komar
After you install the WPI FRC Java plugins, you can just go File -> New Project -> Samples -> FRC Java
There are 5 samples there I believe.
If you need help instalilng the FRC Java plugins, you can look here:
http://first.wpi.edu/Images/CMS/Firs...va_for_FRC.pdf
~Jacob
Unread 14-01-2010, 17:22
AKA: Jacob Komar
Can you link to this update? Can't seem to find it.
Unread 14-01-2010, 17:25
AKA: Brad
#0190 ( Gompei and the Herd)
If you set the update site to:
http://first.wpi.edu/FRC/java/netbea...te/updates.xml
you should be seeing update notifications when you start NetBeans. You can set the "Check Interval" to be every time NetBeans starts to get more timely notification.
Brad Miller
Robotics Resource Center
Unread 14-01-2010, 17:29
AKA: Jacob Komar
http://first.wpi.edu/FRC/java/netbea...0a/updates.xml
Got it.
On a side note, Brad, would you recommend hooking the Classmate to the internet ever? So far I haven't hooked ours up, for fear of junking it up, and so far have only moved files and updates over via USB. I'm considering removing AVG altogether and never connecting it to the web.
Unread 14-01-2010, 19:06
AKA: PICKELL!!!
i did that, but i only have 3 samples
and i did hook it up to the internet, bit idk
Unread 14-01-2010, 19:10
AKA: Jacob Komar
On the right when you first open the new project dialog are some, but if you open the samples folder and then the FRC Java folder, there should be some more there?
Unread 14-01-2010, 19:49
Isn't that a very old update link? I think it should be http://first.wpi.edu/FRC/java/netbea...te/updates.xml
Unread 15-01-2010, 11:26
AKA: Brad
Joe -
Thanks for catching that... you are correct!
To fast on the cutting and pasting. The updates are now at the top level, especially since we added version checking on downloads.
Brad Miller
Unread 18-01-2010, 01:19
jtechau jtechau is offline
AKA: Jeff Techau
FRC #1388 (Eagle Robotics)
jtechau is just really nicejtechau is just really nicejtechau is just really nicejtechau is just really nice
Are you having problems with AVG? I wouldn't recommend removing anti-virus on the belief that you're safe if not connected to the internet. Viruses can be transmitted by USB drives as well. We've had that happen already. No anti-virus software is perfect, but some protection is better than none.
can't run code viper110110 Programming 3 18-09-2009 21:25
Can't figure out the Axis camera setup... 2829ron Technical Discussion 6 20-01-2009 13:12
Can't get auto mode to run with OI switches kiettyyyy Programming 11 15-04-2006 00:05
Out of the box Fundraising... trollin1st Fundraising 10 15-09-2005 19:50
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
