Driver Station to Dashboard Laptop connection
Hi all.
Last year you could connect the Driver Station to a laptop through the ethernet switch in order to use a dashboard. Now that the Driver Station is run on a laptop, is there going to be a way to connect the Driver Station laptop to another laptop that you can run the dashboard on? I'm wary about running a dashboard on the driver station laptop due to the limited performance it has, especially since I'm implementing my own dashboard software. Anyone have any info on this? In the presentation here http://forums.usfirst.org/showthread.php?t=13368 (thanks to Joe for putting it together), it indicates that you re-direct dashboard data to another computer, but how is this done? Last edited by slavik262 : 11-01-2010 at 09:42. |
Re: Driver Station to Dashboard Laptop connection
This appears to be one of the cases where something is supported by the control system, but not allowed in the rules. <R82> says that you can only connect something to the drivers station via USB. <R84> says you can't connect directly to the field ethernet, which seems to rule out a switch. On the other hand, a USB network card connects via USB and you could connect the classmate and second dashboard that way. That is worth clarifying through the FIRST Q/A if you want to go that route.
I have used the dashboard redirection built into the driver station when the second laptop is connected via a switch. However, I only tested it with dashboard data, not the camera. One disadvantage is that data is then only shown on the remote computer, not on the classmate also. To use the dashboard redirection, in the setup tab, select remote dashboard and enter the IP address of the remote dashboard computer. Last edited by Joe Ross : 11-01-2010 at 10:33. Reason: Add <R84> |
Why on earth would they forbid us from using ethernet connections?
At any rate, I've discovered some USB-to-USB network cables. Does anybody know of one that's Vista compatible? A lot of the ones I see are compatible up to XP only. Last edited by slavik262 : 11-01-2010 at 11:09. |
![]() In my opinion, from a software approach, it is best to implement two dashboards... one on the classmate that shows some of your data and also fowards on what data you want to show on the other dashboard. Then the second can just communicate with the first, meaning that the networking is completely up to you since the link between the DS and he Dashboard is independent of the field network. |
If you search "USB Ethernet adapter" on your favorite search engine you'll come up with plenty of options that support your favorite OS (though XP on the classmate is all that matters) for $20 to $30. The rule simply says you can only use USB on the classmate... it doesn't matter how you connect to your dashboard computer. |
| 2010 Driver Station Netbook Driver Account and Java | joshholat | FRC Control System | 2 | 10-01-2010 15:04 |
| Driver station... | the man | Control System | 16 | 06-01-2010 21:06 |
| cRIO configuration issue- serial connection to laptop | Torbots 1197 | FRC Control System | 5 | 28-01-2009 22:28 |
| cRIO/Driver Station output to laptop | smcmahon | FRC Control System | 3 | 14-12-2008 13:51 |
| Dashboard Laptop Questions..... | bigqueue | Technical Discussion | 5 | 07-01-2002 08:30 |
