Go to Post but then again, isn't FIRST a sport? I mean come on now, our championship is nothing less than the super bowl. :) - Arefin Bari [more]
Unread 10-01-2010, 20:34
JohnFogarty's Avatar
AKA: @doctorfogarty
Little Blue Box.. New CRio???
Ok, i'm a sophmore and last year's CRio was a large white module. This year i opened the kit and i found a small board that looked sorta like the main circuit board is that really the new CRio?
John Fogarty
Unread 10-01-2010, 20:53
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Little Blue Box.. New CRio???
Wow... This is a really confusing post... but I guess that's an indication of how confused you are.
Only Rookie teams received a new cRIO in their kit. See here. Veterans are expected to reuse the cRIO and several other key components from year to year.
The cRIO is not white... it's gun metal grey. It has those blue and grey modules that plug into it. I can't think of any large white module last year.
I believe what you found in your kit (if it came in a white plastic case) is a Cypress First Touch Kit 003. This device is expected to be plugged into the classmate Driver Station to provide I/O to knobs or buttons, etc that your team uses on a custom driver console.
-Joe
Unread 10-01-2010, 22:05
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
If it helps at all, there's a picture of the cRIO and several modules on this page.
Unread 11-01-2010, 10:35
AKA: @doctorfogarty
i firgued it out..hah the box i was refering to was one of the digital sidecars. Got it going now. Though i dont quite understand the breadboard yet. I have an even better question now are the XBOX 360 controllers compatible again??
John Fogarty
Unread 12-01-2010, 01:07
The breadboard is just there to provide the some prototyping space for wiring to the Cypress FTK3.
Just install the XBox controller drivers in the developer account.
Unread 13-01-2010, 00:09
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Oh really, this works now?! Great, a lot of people will be happy about that! And this makes sense because you can do that with the Classmate. So, is that all that needs to be done? Have you tried this? How do you know that there's not any more interfacing you need to do? Will it work for the WPI joystick libraries?
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 13-01-2010, 09:56
Chris is me's Avatar
AKA: Pinecone
I've heard wired Xbox 360 controllers can be used. I personally am not a fan of them as the joysticks do not return to exactly the center when released, so you'd have to program in a deadband for the joysticks, decreasing your range of motion. I would recommend a Logitech gamepad if you go that route.
Unread 13-01-2010, 15:51
AKA: @doctorfogarty
we have extra's from FTC which i could use
John Fogarty
Unread 13-01-2010, 18:46
RoboMaster's Avatar
Yeah, we've used a Logitech one in the past. Very simple and down to earth, works great. Xbox controlers look cooler though We'll have to weigh our options.
Thanks again!
pic: Little Panda playing with the big blue ball mtaman02 Extra Discussion 1 20-10-2008 23:34
The little blue demon sonicx059 Chit-Chat 7 26-03-2007 00:52
Little Black Box NOV8R Electrical 3 11-02-2007 00:04
Need a little help with how to break out of the box amateurrobotguy Programming 6 16-01-2006 12:56
pic: Team 356's Little Black Box CD47-Bot Robot Showcase 7 22-02-2004 23:13
