Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 11-01-2010, 22:30
CVassos's Avatar
CVassos CVassos is offline
A man of many subgroups
AKA: Chris Vassos
FRC #2016 (MightyMonkeyWrenches)
CVassos is an unknown quantity at this point
Driver Station Dashboard Problems
I accidentally deleted the default command "C:\Program Files\FRC Dashboard\Dashboard.exe" from the driver station command line, which is inaccessible after the mandatory update is applied. If it is somehow accessible I would really like to know how because the other option is to use the restoration key.
Thank you, Johnson & Johnson, we are very grateful for your sponsorship
Unread 12-01-2010, 07:42
Re: Driver Station Dashboard Problems
The updated driver station no longer shows the command line within the setup page. If the driver station is launching your dashboard, then the value is fine, and you have no reason to reimage. If you are wanting to figure out how to modify which program is run as your dashboard, it is saved into an ini file, all users/documents/setting.ini. That isn't the actual name, but should get you there. The ini file has lots of settings for the drivers station including the path to the exe it will launch as the dashboard.
If I didn't understand the question, please rephrase.
Greg McKaskle
Unread 12-01-2010, 19:05
CVassos's Avatar
AKA: Chris Vassos
the dashboard program is no longer being launched
Unread 12-01-2010, 23:19
I'm not sure what language you are going to use for programming, but LabVIEW has a template project that builds the same dashboard as was originally installed. You can also make modifications and move the EXE to program files. The dashboard EXE that the driver station will launch comes form the ini file, so either name the EXE to match, or change the file to match the EXE name.
Greg McKaskle
Unread 12-01-2010, 23:25
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
I'm having a different dashboard issue...Greg, maybe you can help me out.
Everything runs, and I can get the code to run on the robot but no data is being relayed to the dashboard. I'm running the 2010 Imaging Demo example from Windriver which I believe sends data back to the dashboard.
Unread 12-01-2010, 23:34
Not sure which language you are using, but the sample code form each was sending compatible data that could be displayed in the default dashboard.
Greg McKaskle
Unread 13-01-2010, 00:01
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Greg McKaskle
I'm using C++...hmm...time for some more experimentation I guess.
Unread 14-01-2010, 21:51
ranc ranc is offline
FRC #2489
ranc is an unknown quantity at this point
I get the same issue. In fact, the example out of the box does not work due to a lack of watchdog. After fixing that, the code cannot send an image to the dashboard on the driver station. Do we have to restructure how the dashboard on the driverstation interprets data through some way of accessing the driver station or is that off limits to the teams?
Also, it seems the 2010 Dashboard template given in Labview is of a different format than the driver station dashboard. I've yet to try reading the data with the dashboard on my computer though. I'll try this tomorrow and see if I can get any data.
-Thanks
Unread 15-01-2010, 18:24
The default dashboard that was installed on the Classmates many months ago is indeed different than the game specific one that came in the last update and in the sample source. The sample source and the one from the latest update are the same.
Greg McKaskle
Unread 16-01-2010, 23:27
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Download Dashboard Here.
Driver Station to Dashboard Laptop connection slavik262 FRC Control System 4 12-01-2010 00:37
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Problems with driver station gyaniv FRC Control System 2 13-02-2009 01:21
