Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
View Poll Results: Should a robot be built to go over the bump or under the tower?
Over the bump 150 81.52%
Under the tower 34 18.48%
Voters: 184. You may not vote on this poll
Unread 12-01-2010, 07:22
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
Over the bump or under the tower
I would like the community's oppinion on whether a robot should go over the bump or under the tower. My team is almost completeley split between the two options.
Unread 12-01-2010, 07:25
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Over the bump or under the tower
Protect for either?
(since 2004)
Unread 12-01-2010, 07:29
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
i would have to go with going over the bump because making a robot that can go through the tunnel really limits what space you have. Going over the bump also gives you more freedom as to were you can cross sections. It's also harder to block people going over the bump.
Unread 12-01-2010, 07:32
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
What about both, or for arguments sake, neither?
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 12-01-2010, 07:42
Mentor now :(
AKA: Ian Pudney
Well it would possible to both go over the bump and go under the tower, or do neither, but personally I think that if you build it with the height limitation of the tunnel then it would be pointless to go over the bump, and if you dedicate the time to build a drive train to go over the bump then it would be pointlesss to limit your height. As for doing neither, it seems like a very bad choice to limit your robot in that way.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 12-01-2010, 08:04
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
My personal suggestion to you is, Design the Robot to go over the Bumps. The tunnel is easily blocked.
I have a Personal Motto when It comes to decisions like this:
It's Always Better To Be Able to Do something and Not Have to, than to Have to Do Something And Not Be able to.
Unread 12-01-2010, 08:49
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Over the bump. Especially with 2 inches of clearance if you make a robot 28 inches wide and with bumpers attached, that will be a pain to get through especially when coming back towards you.
1058 PVC Pirates 2016 - xxxx
Unread 12-01-2010, 08:52
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
My vote would have to be neither also, but since that wasn't an option I voted over. I like the analogy that someone made to foosball. I think that the best strategy is if everyone stays in their aisle and just fowards the ball to the next section. But, I do agree that it is a good idea to have the flexability to cross the border in an emergency situation. 810 will certianly not be trying to cross the bump, but the option will definitely be there.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 12-01-2010, 08:58
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
We are planing on going under the tower but use the bump as a second option.
I dont think the height restriction of the tunnel is to bad. It you go over the bump your going to want a low center of gravity which limits your height or at least where your weight is at.
Every day is a new adventure!!!
Unread 12-01-2010, 08:59
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Then based on your quote, you should design to do both as there may be times when you want/need to go through the tunnel.
Unread 12-01-2010, 09:09
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I can see being able to retrieve a ball that is in the tunnel as important.
The Kickoff showed how easily a ball can (and will) roll under there.
___________________
- Tennyson, Ulysses
Unread 12-01-2010, 09:14
The Mad Chemist
FRC #2791
That was my thought as well
Unread 12-01-2010, 09:20
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Do a cost/benefit analysis of going over the bump vs. going under the tower. Having a clear and objective reason to pursue one or the other, balanced with your team's resources and abilities, will help your team decide on a system that matches your overall design.
Having said that, and having done that with our team, we're bumping, and according to the poll it looks like most others are as well.
However, don't base your decisions on what is most popular. As JVN said (paraphrased), the cool factor doesn't win competitions.
Hi!
Unread 12-01-2010, 09:25
KrakatoaCoo's Avatar
KrakatoaCoo KrakatoaCoo is offline
UNRegistered User
FRC #0348 (Norwell Robotics)
Team Role: Animator
KrakatoaCoo is an unknown quantity at this point
i'd use over bump as most teams would block the tunnels but having both on your robot gives an advantage
Nerds aplenty?.....
Unread 12-01-2010, 09:36
Chris is me's Avatar
AKA: Pinecone
I think if your strategy revolves around crossing the zones, strictly going under the tower won't cut it. That's too easy to defend.
Devils' Tower first rise under power! Stu Bloom Robot Showcase 16 18-02-2005 11:20
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
How long is the bump from the ramp to the top? Tton Rules/Strategy 1 09-01-2003 18:26
over/under the rail archiver 2001 8 24-06-2002 01:03
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
