Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 12-01-2010, 10:13
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Grappling hook?
Is it possible to have a hook shoot up at an angle with strong rope attached and latch on to the tower (assuming its in the height limits). then is it possible to reel the rope in?
This is just an idea our team has had and im wondering if it can be accomplished.
Unread 12-01-2010, 10:25
vg674's Avatar
vg674 vg674 is offline
FRC #0118 (Robonauts)
vg674 is an unknown quantity at this point
Re: Grappling hook?
The only problem I would see is with the entanglement of robots or being hazardous to people. Rules <R03> to <R06> seem to say that it is essentially too dangerous to do so, and understandably so. I can only imagine a grappling hook shooting the wrong way and ramming into players or refs or destroying the field... not so great. Good idea though!
The board is a mirror of the mind of the players as the moments pass. When a master studies the record of a game he can tell at what point greed overtook the pupil, when he became tired, when he fell into stupidity, and when the maid came by with tea.
- Anonymous Go player
Unread 12-01-2010, 10:26
Sean Raia's Avatar
Re: Grappling hook?
Yeah that was one of our concerns, and i doubt we will be using the grappling hook idea. But would it be possible to shoot the grappling hook out or reel the rope in and lift a 120 pound robot in the first place?
I want to know weather or not we should consider it as a plausible idea.
Unread 12-01-2010, 10:36
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Re: Grappling hook?
http://www.chiefdelphi.com/forums/ne...reply&p=897181
Originally Posted by Kevin Sevcik View Post
To bring a little more "training" to the discussion... you just have to look at the maximum power of your motors to determine the absolute fastest you can get a robot up.
Power = Work / Time
Work = Force * Distance
so
Power = Force * Distance / Time
or
Power = Force * Speeeeeeeed
The CIM motors max out at 343W = 252 lbf*ft/s
So the fastest an optimally geared CIM will lift a bot is about 1.5 ft/s. Or you lift in about a second.
Mind, this assume you're instantly at the max power point, no friction losses, spherical chickens, the works. But, lifting your robot 20" in, say, 5 seconds is easily doable if you gear it right. The gearing it right being key. Max power occurs at 1/2 stall torque. But I'd really aim for 1/4 - 1/3 stall torque for your full load, for safety and losses and all that.
vg674's Avatar
Re: Grappling hook?
With the right material, I would say that that wouldn't be a problem at all. There are many ways to lessen the strain, and I think it would be quite easily possible to engineer a way, be it pulleys or a fancy combination of motors to use a grappling hook to hang from the bar, and even great in the respect of not needing power while removing the robot. Again, I see the main concern as safety, and I think that will be the deciding factor.
Unread 12-01-2010, 10:43
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Grappling hook?
We thought of this exact thing as well last night. Though we may have an idea on how to control it.
John Fogarty
Unread 12-01-2010, 10:45
JIMBO4341's Avatar
JIMBO4341 JIMBO4341 is offline
FRC #2151
JIMBO4341 has a spectacular aura aboutJIMBO4341 has a spectacular aura about
Re: Grappling hook?
I don't think this is possible as I think it's likely that you would exceed your vertical allowance. The bars are 84'' high your maximum is 90'' so there's only 6 inches of leeway for your shot to fly over the bar and grapple. Also if you happen to miss you would almost surely exceed your horizontal allowance. They teased us with the grapple bot in the kickoff video .
Unread 12-01-2010, 10:46
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Re: Grappling hook?
I saw several bots hang in 04 using hooks but the all had some type of arm extend up with hook on end to catch the bar and the hook and cable were velcroed so they would release from the arm and winch up the bots. Only purpose of the arm was to place the hook.
Unread 12-01-2010, 10:48
AKA: @doctorfogarty
Re: Grappling hook?
make sure the cable atached to your grapple is shorter than what the max is.
John Fogarty
Unread 12-01-2010, 10:54
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Re: Grappling hook?
There are ways of using cables without "shooting" them up there. A shot is also inaccurate, dangerous, and possibly could go over the height limit... Try and think of more controlled ways to have a hook go up... you're on the right track with cables...
Cold Fusion's 10th Season
Unread 12-01-2010, 12:13
Sean Raia's Avatar
Re: Grappling hook?
I think our team is actually going with a scissor lift mechanism with hooks on the top. we want to be able to go under the tunnel. I just thought the grappling hook was a neat idea for discussion, and im from what i read its possible and legal if it doesn't go outside the dimensions.
Unread 12-01-2010, 12:25
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Re: Grappling hook?
we decided to opt out of the hook because the max hight during FInal Configuration is 90 in and the towers height is 84 in so the hook only has 6in to make it over and we didn't want to risk going to high.
<G40> also might say its a no go because of the entanglement issue
edit: sry i re-said things others did i didn't notice them until i reread the thread
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 12-01-2010, 14:03
Re: Grappling hook?
Of course you can lift a robot using a hook and cable as described. We have done it. There will some risk involved this year...
<G31> BALL RETURN and RETURN BARS Protection - ROBOTS may not contact the BALL RETURN or the RETURN BARS (black tape). Violation: PENALTY for inadvertent contact; plus a RED CARD for obviously intentional contact or damaging contact.
Unread 12-01-2010, 14:37
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
Re: Grappling hook?
it's very plausible. if you could get the accuracy, you should have the strength pretty easily after that. after all, mountain climbers+ gear tend to be well over 120 lbs, and those ropes will easily hold the weight.
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Unread 12-01-2010, 14:46
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: Grappling hook?
Case in point, Team 811:
The black pole on the right telescoped out ~15 feet to put the grappling hook over the 10' chin-up bar, and then a window motor (legal then) pulled Red Streak II into the air v-e-r-y s-l-o-w-l-y .
"It's NOT Just A Robot Thing!"
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
How to Hook up LCD magical hands Programming 18 04-03-2007 13:18
HOOK 'EM HORNS!!!! xzvrw2 Chit-Chat 18 06-01-2006 22:40
Hook edomus General Forum 2 23-02-2004 19:00
Batttery hook up piconysm Technical Discussion 3 17-01-2002 18:21
