Go to Post (You know you're overdosed on FIRST) when watching regional web-casts takes precedent over Saturday morning cartoons. - Hawiian Cadder [more]
Unread 10-01-2010, 15:49
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Autonomous Program Switch
we use this in FRC 2009
see pic
ID:	8253  Click image for larger version
ID:	8254  Click image for larger version
ID:	8255  Click image for larger version
TEAM 1946-Tamra
Unread 12-01-2010, 07:54
We have been using a program select switch at the DS for many years. Using a modified Radio Shack rotary switch and an analog input we can select one of 11 different program settings. A search of this site will turn up some interesting past discussions.
Unread 12-01-2010, 10:18
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
Last year we used three SPST on the DS (mounted on a piece of polycarb) to set autonomous modes by treating each one as a binary bit, giving us 8 possible auto modes. This system is simple to use and remember, can be changed right up until you step back, and can easily be expanded by adding another switch. I'm not sure how the implementation would work with the new driver station system, but we have also used the same switch setup on the robot ('08 I think) when we couldn't get a signal to pass from the driver station to the robot during auto.
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 12-01-2010, 13:13
Racer26 Racer26 is offline
Yup, selectable autonomous is doable from both the DS and Robot end of the equation, though admittedly, I feel its easier and less prone to muck ups from the Robot end.
Its been being done by lots of teams for many years.
My team specifically has been using a device called a thumbpot, i think. It is a 2 digit selector with + and - keys for each digit, and reports an analog voltage back to the cRIO. Some fancy code to turn that back into the number shown on it, and away you go.
Unread 12-01-2010, 13:47
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Originally Posted by Imadapocalypse View Post
I am not sure if this is entirely possible but i was wondering if it possible to create a physical switch on your robot to toggle between autonomous programs.
I know it has been answered, bu yes. You can indeed do this.
We had a set of several switches on our robot. Basically it was like writing down rules. Go forward or back, next switch said how far, ect. ect. Now with last years floor... We never perfected it.
Maybe this year?
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 11-02-2010, 19:58
Dennis Erickson Dennis Erickson is offline
FRC #1510
Dennis Erickson is an unknown quantity at this point
Red face Re: Autonomous Program Switch
If you want a very simple solution you can use the USER1 switch on the cRIO. Using the "FRC ReadSwitch.vi" will return its position. This is a very small switch and you should be carefull when using it. Do not move the other switches in the area.
Unread 12-02-2010, 15:00
Heath's Avatar
Heath Heath is offline
AKA: Kevin Heath
FRC #2840 (PCDS Robotics)
Heath is an unknown quantity at this point
Last year, our team made a box with three switches that we connected to the digital IO sidecar that gave us more possible autonomous modes than we actually used. However, we discovered a little to late that there was actually a pre-made block to determine your starting position in the WPI robotics library. It may still be applicable this year.
"There is no spoon"
Team 2840
Unread 12-02-2010, 15:11
Originally Posted by Heath View Post
...there was actually a pre-made block to determine your starting position in the WPI robotics library.
It only tells you which spot in the alliance station your controls are assigned to. It doesn't have anything to do with where on the field your robot starts.
Autonomous Controller Board Switch merybar Technical Discussion 9 25-03-2008 08:04
Autonomous Controller Board Switch merybar General Forum 2 27-01-2008 12:54
pic: Autonomous Mode Switch Gary Bonner Robot Showcase 4 18-02-2005 21:58
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
