Go to Post I can tell you for a fact that students don't need smartphones in order to unproductively entertain themselves in a robotics lab. - remulasce [more]
Unread 12-01-2010, 11:23
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
Using Encoders
So my team(781) wants to use encoders because one of our motors spins forward while the other spins backward to move our robot forward. Snce the motors do not spin the same speed with the same amount of energy we must use encoders. However we have no experience with this. Can you help us program and initialize the encoder?
Thanks,
Team 781
Unread 12-01-2010, 11:37
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Using Encoders
Well, you don't *have* to use encoders. If all you were concerned about was that they were spinning the same rate, just figure out how much faster the other motor can spin, then scale the input to the motor appropriately (using the assumption that the motor response AND the output from the motor controller is linear).
Of course, thats a really quick and dirty approximation, and makes a lot of assumptions. If you want them to be matched using encoders, then you probably want to look into using PID control for this problem. Do a search on the forums, there's lots of stuff about that type of thing there.
Unread 14-01-2010, 16:43
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Using Encoders
Check out the Encoder class and associated documentation. You connect the A and B channels to digital inputs and supply the port numbers to the Encoder constructor. From there you can read the counts or rate.
You can also connect it to a PID object to control direction. For driving straight you can use something like the right-left encoder value. As one side gets ahead the value will swing either positive or negative and the PID class can apply the necessary correction to the turn rate.
Brad Miller
Robotics Resource Center
Using more than 4 encoders stuartd Programming 3 10-03-2009 00:47
[FTC]: Progress report on using encoders PhilBot FIRST Tech Challenge 11 14-11-2008 14:01
Autonomous using encoders Mr.G Programming 11 17-01-2006 03:34
Using Digi-Key Shaft Encoders D.Viddy Programming 45 02-01-2005 20:11
Using Shaft Encoders D.Viddy Programming 7 14-12-2004 18:27
