Go to Post We are reluctant to deprive you of the experience of learning how to do your own research. - Alan Anderson [more]
Unread 12-01-2010, 11:43
CaptainMorton CaptainMorton is offline
FRC #0888
CaptainMorton is an unknown quantity at this point
Classmate vision software error
We have recently ran our class mate and installed the update and activated LabView 8.6 with the labview activation serial number found on their website.
We cant access NI Vision Assistant 2009 because it say our trial is over.
Our vision code doesn't run either due to the inactivation of the vision assistant.
How should we activate it?
Unread 13-01-2010, 16:37
NI-Bob NI-Bob is offline
NI-Bob is an unknown quantity at this point
Re: Classmate vision software error
Hello,
The FRC Software is all licensed through one License File. This will contain all of the information for LabVIEW and Vision etc. Are you able to load LabVIEW without being prompted for activation?
Can you load the NI License Manager (Start > Programs > National Instruments > NI License Manager) and try to right click on the Development System underneath LabVIEW 8.6.1 and select Activate. If you still cannot open Vision Assistant 2009 after this it is possible there is an issue with your License File.
Can you give us a Screen Shot of what your License Manager looks like? Make sure to have First Robotics Competition selected on the left hand side so that we can see the detailed information.
I also should be able to create a new License File for you. In order to do this I will need your serial number as well as the Computer ID. You can get the Computer ID by clicking Display Computer Information from the License Manager.
Please keep me updated and I will be happy to help you get this activated.
Thanks!
Bob H
NI FIRST Support
Unread 14-01-2010, 10:19
FRC #0888
We just reinstalled the FIRST Labview Vision Software with an external cddrive with the disk provided and it worked
Thanks
Unread 14-01-2010, 10:28
Glad to hear! It sounds like the first install may not have completed properly. If you run into any further issues down the road feel free to post on the NI FIRST Forums as well.
Have a great day!
Thanks!
Bob H
NI FIRST Support
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Classmate Issues ROFLcopter NI LabVIEW 10 16-01-2010 21:56
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
Classmate PC Error scottydoh FRC Control System 2 12-01-2010 14:55
Classmate PC - Front Panel jmanela NI LabVIEW 28 23-08-2009 20:36
