Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 12-01-2010, 12:16
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
Re: Suction as a method for possessing balls
As long as the ball stays on the ground it is considered POSSESION which is perfectly legal. If the ball comes off the ground that is considered HOLDING which is a penalty.
Unread 12-01-2010, 18:14
Bob Steele's Avatar
Bob Steele Bob Steele is online now
AKA: Bob Steele
the key is that any ball on the ground can be in possession of the robot.
Any ball OFF the ground and in possession would be CARRIED... that is a penalty.
Carrying can occur ANYWHERE on the robot... the key is that the ball MUST stay in contact with the ground.
Any vacuum system would have to be designed to keep the ball on the ground...
Unread 12-01-2010, 18:19
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
So a robot that is controlling a ball via suction goes over a bump. At some point, that ball is going to lose contact with the ground. Would this be a carry?
edit: I realize this should be an official Q&A but I'd like to see what you fine folks think.
Hi!
Unread 12-01-2010, 18:37
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How would this not be a penalty? The rules explicitly state you cant be in control of a ball thats not in contact with the ground.
Mentor 2415
Unread 12-01-2010, 18:42
It's not intentional, and probably momentary. It's like having the ball bounce off your hand in soccer--the refs probably won't call that, especially if you don't make any move to control the ball or your hand is against your body, but they can if they think it's intentional on your part.
Yes, definitely one for Q&A.
Unread 12-01-2010, 18:49
AKA: Sean
IDK the fact that you know you designed your robot so that it violates that rule whenever you go over a bump sounds pretty intentional. I agree its definitely not an easy thing to work around but so far it seems pretty explicit.
Mentor 2415
Unread 12-01-2010, 18:53
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
in overdrive 1986 (Team Titanium) used a suction cup to move the track balls, it worked extremely well compared to initial thoughts.
Unread 12-01-2010, 18:57
sami9145's Avatar
sami9145 sami9145 is offline
AKA: Samantha Gainey
FRC #2333
sami9145 will become famous soon enough
Suction... hadnt thought about that yet but it seems fun!
to answer the bump problem... as long as the vaccuum suction is turned off when you go over the bump so its not holding the ball would it still be possession if it "happened" to go over the bump with you even tho you had no hold on it at that time?
i will put this idea to my team tho >.>
FRC Team 2333
2008-2009 team member
2009-2010 co-captain
FTC Team 3679
2009-2010 team captain
Unread 12-01-2010, 19:13
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Suction may work, but it seem that the ball needs to drag on the ground, and not roll.
"WANTED - Schroedinger's cat. Dead and alive." 五行
Unread 14-01-2010, 00:10
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I think its almost impossible to cross the bump while possessing a ball. If you try to go up the bump with the ball in front of you, the ball will raise off of the surface as you reach the flat of the bump and thats saying the ball doesn't jam you up at the bottom of the incline and possibly causing you to climb on top of the ball. If you try to drag the ball behind you as you climb up the ramp, it will again come off of the surface as you level out on the flat and as you descend down the bump.
Although, what usually happens is I get proved wrong......
Unread 14-01-2010, 03:45
Iceman1330's Avatar
Iceman1330 Iceman1330 is offline
FRC #2523 (Lab Rats)
Iceman1330 is an unknown quantity at this point
You would violate the rule if the ball was held static to the robot. However, if your vacuum end effector was on a articulated member such that the weight of the ball at the end always held it against the ground (no matter the angle of your robot) I could see this working.
Unread 14-01-2010, 09:05
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Incorrect. You would be in POSSESSION of a ball, which you are alowed to do as long as the ball is in contact with the floor.
If the ball came off of the carpet then you would be CARRYING the ball, which is a penalty.
___________________
- Tennyson, Ulysses
Unread 15-01-2010, 01:38
Iceman1330's Avatar
Which is exactly why what I described does not incur a penalty. If the ball always remains in contact with the floor then you are not carrying.
Others seem to suggest a vacuum system which is rigidly attached to the frame. If they did this and if they went over a bump the ball would lift in the air (because their robot would lift into the air) and they would incur a carrying penalty. Utilizing an articulated vacuum mechanism the ball will always remain in contact with the floor.
Orbit Balls - For Sale Pelicano234 General Forum 53 02-02-2009 23:47
Alternative Method for calculating “I” term in PID Holtzman Programming 15 06-09-2006 13:22
Balls for the game K.Shaw General Forum 1 20-01-2004 17:59
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
adhesive for grabbing balls archiver 2001 1 23-06-2002 22:40
