Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
  #46   Spotlight this post!
Unread 11-01-2010, 23:27
President, VEX Robotics, Inc.
Re: Serial to CAN Gateway in new Black Jaguars?
Trusted mode and untrusted mode are no longer necessary. The current Jaguar firmware expects a "token" when sent a throttle request via CAN. This token is generated by the cRIO. If the CAN frame setting throttle does not contain the token the Jaguar sets its output to 0. This latest implementation allows teams to create there own CAN nodes without having to use PWM cables and allows teams to generate CAN frames over Ethernet.
-Mike Copioli
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #47   Spotlight this post!
Unread 12-01-2010, 00:10
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
Originally Posted by ajlapp View Post
I previously recall someone mentioning that both pwm an CAN cables had to be connected to a jaguar for a heartbeat message. It sounds to me like this isn't the case.
My interpretation of that is that the Jaguars can only receive signals over one medium or the other (CAN or PWM). I believe that this means they can both be used, like CAN for a primary controller and PWM signals as a backup if for instance your Black Jaguar dies and you no longer have a convertor. That would still allow for operation of other motors if you can detect the loss of signal.
Just my interpretation, I would suggest a Q&A be posted about this point thought if this is actually going to be used.
  #48   Spotlight this post!
Unread 12-01-2010, 00:16
I think the rules are pretty clear. CAN or PWM - choose one.
As Mike said, the "both" option is vestigial and not legal for 2010. This is actually a boon, the "both" option is ugly to be honest.
  #49   Spotlight this post!
Unread 12-01-2010, 14:38
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Team Update #1 has clarified the issue of connecting sensors directly to the Jaguar inputs.
It is now legal to connect sensors or custom circuits to the Jaguar inputs per rule <R68-H>
  #50   Spotlight this post!
Unread 18-01-2010, 23:42
woodk woodk is offline
FRC #2809
woodk has a spectacular aura aboutwoodk has a spectacular aura aboutwoodk has a spectacular aura about
Current mode ... or any mode other than voltage
Has anyone got current mode to work on the jaguars?
Or any other mode other than voltage?
I got it running from a PC using the bdcomm (I think its called) app. However, the c++ code supplied only supports voltage mode. I've been trying to modify it to add other modes, but no success yet.
- Kevin
  #51   Spotlight this post!
Unread 19-01-2010, 01:44
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Current mode ... or any mode other than voltage
- Kevin
What does current mode do?
I know that the jaguar can adjust the amount of current drawn through pulse-withing the motor power, but is it running at full speed during that time?
I have only tried experimenting with the voltage control mode at this time, but the low speed control (over CAN) seems to be much better then before.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
  #52   Spotlight this post!
Unread 19-01-2010, 07:47
Kevin,
The Jaguar controls average current by pulse width modulation but the pulses can only go between 0 volts and the battery terminal voltage (12 volts nominal.). Are you thinking of current sense? That is available through the CAN bus. There is a series resistor built into the Jaguar and the voltage drop across that resistor can then be used to calculate current through the device.
  #53   Spotlight this post!
Unread 19-01-2010, 08:10
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Current control mode allows users to servo the output of the Jaguar to a given current. PID gains can be set to change the Jaguars response to changing conditions. The maximum current that can be obtained if finite and determined by several factors including the maximum output voltage and duty cycle of the Jaguar.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #54   Spotlight this post!
Unread 25-01-2010, 20:20
Zanfardino2892's Avatar
Zanfardino2892 Zanfardino2892 is offline
AKA: Mark Zanfardino
FRC #2892 (Hottie Botties)
Zanfardino2892 is an unknown quantity at this point
Are the black jags (MDL-BDC24) legal this season. Where is this referenced? and what are the advantages.
  #55   Spotlight this post!
Unread 26-01-2010, 07:32
Under this rule for starts...
<R42> Items specifically PROHIBITED from use on the ROBOT include:
D. Motor speed controllers other than Innovation First, Inc. “Victor 884” speed controllers or Luminary Micro/Texas Instruments “Jaguar” (MDL-BDC or MDL-BDC24) speed controllers,
You will also find reference to the Black version needing to be the first in line when using the CAN bus.
Where can we get PS2 type game controllers with serial ports? waialua359 Control System 12 25-01-2006 22:33
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
VXML Gateway to Web Databases Adrian Wong Rules/Strategy 11 08-10-2001 08:10
