Go to Post Do it the good ol' American way and throw money at the problem. In other words, get out of there and call a professional to take care of it. - sanddrag [more]
Unread 12-01-2010, 17:44
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Kicking System Design Considerations
A kicking system can be described as a mechanical manipulator used to accelerate a ball to a desired velocity to a desired trajectory. This can be achieved in many different ways with various actuators. Check out this research paper Segway CMBalance Robot Soccer Player. http://www.dtic.mil/cgi-bin/GetTRDoc...c=GetTRDoc.pdf
The paper presents information necessary to design and implement a soccer ball manipulation system for a mobile robot such as ours. We used to concepts in this paper to design the pneumatic kicking system we are going to use.
Unread 14-01-2010, 11:04
kamus1000's Avatar
kamus1000 kamus1000 is offline
Lucas
FRC #1382 (Etep Team)
kamus1000 is an unknown quantity at this point
Re: Kicking System Design Considerations
Don't you think that the maximum pressure is not enough to use the pneumatic system the times we need?
"You can do anything if you have enthusiasm."
(Henry Ford)
ETEP Team #1382 http://www.etepteam.com.br/
Unread 14-01-2010, 11:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That probably depends on how far you think you need to kick the ball.
Unread 14-01-2010, 12:14
kamus1000's Avatar
Lucas
We are testing the pneumatic and see if we can use it to throw the ball into the goal or make the ball cross the bumper, but I think that we are going to lose so much pressure in only one shoot trying to cross the ball.
(Henry Ford)
Unread 14-01-2010, 12:49
kwotremb's Avatar
kwotremb kwotremb is offline
FRC #3414
kwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to behold
We had a mechanism last night going with pnuematics that was kicking the ball just fine over a bump. Not enough for the field, but a bump just fine. Going to try tonight to see if we can make it kick any further, but at least gettting the ball from zone to zone or pushing a ball into a goal should not be a problem. Im sure some teams will be launching it the length of the field with pnuematics. (remember levers are your friend)
2013: Team 3414 Hackbots
Waterford District: Finalist (51, 3604)
Livonia District: Winner (3641, 240), Spirit Award
MSC: 6th Seed Captain (862, 3641), Spirit Award
Worlds: Seeded 32 in Curie
Past Years:
Team 3414: Hackbots, 2013-Current, Mentor
Team 818: Steel Armadillos, 2008-2012, Mentor
Team 93: N.E.W Apple Corps, 2002-2003, Student
Unread 14-01-2010, 15:46
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
If I may ask, how did you have the pneumatics set up?
We had compressor -> two tanks -> regulator -> two tanks -> switch -> piston and the hit was rather wimpy. The piston was a 1.5" OD x 2" stroke. Thanks.
Unread 14-01-2010, 16:23
MrForbes's Avatar
AKA: Jim
842 is using a 2" bore by 12" stroke piston....
http://www.youtube.com/watch?v=QLH-XqNyQ-0
takes a lot of power to move that ball fast, so you need a pretty big cylinder
Unread 14-01-2010, 17:03
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
1583's design uses several 1 1/2 inch x 2 inch stroke cylinders and yes they are levered to the kicking plate. We are building a full size prototype now. Don't forget you need some type of ball control mechanism to hold the ball against the kicking plate. We're prototyping one of those now also.
Unread 14-01-2010, 17:07
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
and the key to getting a 2" cylinder to fire quickly is to pre-load it. If you watch the video you will see them manually releasing the mechanism, not just cycling the valve.
Unread 14-01-2010, 17:43
run the trap!!!
Team Role: Human Player
The problem with pneumatics is that the bigger you go the slower the piston fires.
There are many ticks to speed up pistons. Preloading is a good option.
One idea I had was to use a mechanism like the pedal on a base drum to "gear up" the piston, allowing it to swing quickly.
We were able to get about 14' of range and about 18" of height with a simple 1.5" bore piston.
-Philip J. Fry
Unread 14-01-2010, 18:50
ricky finethy ricky finethy is offline
FRC #0319
ricky finethy is an unknown quantity at this point
Cool Re: Kicking System Design Considerations
i dont like a kicking design my self i look at the desing like a rotary vs a piston engin the rotary spins with no starting and stoping while the pistion engin has to start and stop all the time
Unread 14-01-2010, 20:04
kwotremb's Avatar
FRC #3414
That is what our basic design will be when we full start building things. Right now we are using a 1.5 bore 8 inch stroke that has been in the KOP before. We are going right from the schools shop 120 psi tanks to a regulator to 60 psi, then the 2 small tanks we can use, then the valve and piston. Right now we just have some wood rigged up to get a prototype going. We are going to get some smaller diameter pistons to see if kick faster/further or not, hopefully get them in next week, or else we know the 1.5 bore works fine.
Right now we have the piston attached a little over half way up a 13 or so inch bar, then a 'foot' at the end of that bar that kicks the ball. We had the ball consistently going over 14 or so feet in the air, enough to get from one section to the next. I think our max was over 17 feet with one of the configurations we tried. We even put a ball about 2-3 feet in front of our kicker to simulate starting positions of the balls and it went right up and over.
Just out of curiosity, what are other teams doing to return their piston to the starting point. Right now are are planning on using some surgical tubing, because if you keep the exit valve open when you kick you can get more speed from the piston.
Past Years:
Unread 14-01-2010, 22:32
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
If you need to increase the force coming from your piston, and/or speed it up you could always consider adding a spring or tying some surgical tubing in a way that it will assist the firing mechanism(up to doubling the power of a single piston stroke), however if you lose too much pressure, you may not be able to retract the pneumatics quick enough to abide by the rules.
I though id throw this power and thought generating idea out for you to kick around.
Unread 17-01-2010, 22:28
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
My team has been trying to figure out how to do it our selfs. We tried 3 or 4 tanks with a 1.5 inch bore with an approximate 5 inch stroke. We managed to get the ball about half way up the bump when we were about 5 feet away. BTW, does anyone know how many balls we're allowed to kick at once?
Unread 17-01-2010, 22:32
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Only one that is in your possession...
Bumper bracket and weight considerations ajlapp General Forum 26 30-09-2008 15:36
FIRST in Motion System Design Elgin Clock FIRST In the News... 0 07-05-2008 15:28
**FIRST EMAIL**/Pre-Order Lunch and Airline Considerations Mark McLeod FIRST E-Mail Blast Archive 0 07-04-2008 18:02
Rookie Workshop Mechanical Considerations Presentation ahecht Technical Discussion 0 07-01-2006 01:06
Kicking around an idea for an RCX buzzer system...thoughts? Billfred Lego Mindstorm Discussion 7 16-07-2005 21:25
