Thread Tools |
Rating:
Display Modes |
Re: Suction as a method for possessing balls
So a robot that is controlling a ball via suction goes over a bump. At some point, that ball is going to lose contact with the ground. Would this be a carry?
edit: I realize this should be an official Q&A but I'd like to see what you fine folks think. |
How would this not be a penalty? The rules explicitly state you cant be in control of a ball thats not in contact with the ground.
It's not intentional, and probably momentary. It's like having the ball bounce off your hand in soccer--the refs probably won't call that, especially if you don't make any move to control the ball or your hand is against your body, but they can if they think it's intentional on your part.
Yes, definitely one for Q&A. |
in overdrive 1986 (Team Titanium) used a suction cup to move the track balls, it worked extremely well compared to initial thoughts.
Suction... hadnt thought about that yet but it seems fun!
to answer the bump problem... as long as the vaccuum suction is turned off when you go over the bump so its not holding the ball would it still be possession if it "happened" to go over the bump with you even tho you had no hold on it at that time? i will put this idea to my team tho >.> |
#7
Suction may work, but it seem that the ball needs to drag on the ground, and not roll.
| Orbit Balls - For Sale | Pelicano234 | General Forum | 53 | 02-02-2009 23:47 |
| Alternative Method for calculating “I” term in PID | Holtzman | Programming | 15 | 06-09-2006 13:22 |
| Balls for the game | K.Shaw | General Forum | 1 | 20-01-2004 17:59 |
| What is your favorite method for attaching gears to shafts? | archiver | 2001 | 13 | 24-06-2002 04:00 |
| adhesive for grabbing balls | archiver | 2001 | 1 | 23-06-2002 22:40 |
