Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 11-01-2010, 20:51
Nick Rixford's Avatar
Nick Rixford Nick Rixford is offline
FRC #0126 (Gaelforce)
Nick Rixford will become famous soon enough
Send a message via AIM to Nick Rixford
Re: Suction as a method for possessing balls
Originally Posted by Chris is me View Post
Sounds like it's legal, though I have only seen one good suction device in FIRST (1771 in 2008) and video of several bad suction devices.
well i believe that it is legal...the only problem i would really have is trying to get it past the bumps if the robot cant fit through the tunnel, isnt it a penalty for a robot picking up a ball?
Unread 12-01-2010, 12:16
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
As long as the ball stays on the ground it is considered POSSESION which is perfectly legal. If the ball comes off the ground that is considered HOLDING which is a penalty.
Unread 12-01-2010, 18:14
Bob Steele's Avatar
AKA: Bob Steele
the key is that any ball on the ground can be in possession of the robot.
Any ball OFF the ground and in possession would be CARRIED... that is a penalty.
Carrying can occur ANYWHERE on the robot... the key is that the ball MUST stay in contact with the ground.
Any vacuum system would have to be designed to keep the ball on the ground...
Unread 12-01-2010, 18:19
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
So a robot that is controlling a ball via suction goes over a bump. At some point, that ball is going to lose contact with the ground. Would this be a carry?
edit: I realize this should be an official Q&A but I'd like to see what you fine folks think.
Hi!
Unread 12-01-2010, 18:37
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How would this not be a penalty? The rules explicitly state you cant be in control of a ball thats not in contact with the ground.
Mentor 2415
Unread 12-01-2010, 18:42
It's not intentional, and probably momentary. It's like having the ball bounce off your hand in soccer--the refs probably won't call that, especially if you don't make any move to control the ball or your hand is against your body, but they can if they think it's intentional on your part.
Yes, definitely one for Q&A.
Unread 12-01-2010, 18:49
AKA: Sean
IDK the fact that you know you designed your robot so that it violates that rule whenever you go over a bump sounds pretty intentional. I agree its definitely not an easy thing to work around but so far it seems pretty explicit.
Mentor 2415
Unread 12-01-2010, 18:53
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
in overdrive 1986 (Team Titanium) used a suction cup to move the track balls, it worked extremely well compared to initial thoughts.
Unread 12-01-2010, 18:57
sami9145's Avatar
sami9145 sami9145 is offline
AKA: Samantha Gainey
FRC #2333
sami9145 will become famous soon enough
Suction... hadnt thought about that yet but it seems fun!
to answer the bump problem... as long as the vaccuum suction is turned off when you go over the bump so its not holding the ball would it still be possession if it "happened" to go over the bump with you even tho you had no hold on it at that time?
i will put this idea to my team tho >.>
FRC Team 2333
2008-2009 team member
2009-2010 co-captain
FTC Team 3679
2009-2010 team captain
Unread 12-01-2010, 19:13
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Suction may work, but it seem that the ball needs to drag on the ground, and not roll.
"WANTED - Schroedinger's cat. Dead and alive." 五行
Unread 12-01-2010, 19:18
Are Jay's Avatar
Are Jay Are Jay is offline
AKA: R.J. Garduno
FRC #2486 (CocoNuts)
Team Role: Driver
Are Jay is an unknown quantity at this point
I don't see why using a suction method would be illegal. But like others have said, it doesn't seem like it would be the most efficient way to hold a ball.
Doing things the shortest or easiest way is an engineer by trade…
- RJValle
Unread 12-01-2010, 20:05
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
My team has been considering this option, and our tests with a shop vac proved sufficient for further investigation. But what to use for suction? I guess I would use a house vacuum's fan attached to a Fisher Price motor?
Go REX!!!
Unread 12-01-2010, 20:12
GaryVoshol's Avatar
Cogito ergo arbitro
At least the field includes the bumps. If you can manage to keep the ball in contact with the carpet, no penalty. But I bet that ends up being difficult.
6.2.1 The FIELD
The playing FIELD for Breakaway is a 27-foot by 54-foot carpeted area, bounded by two ALLIANCE WALLS and a Guardrail System. The FIELD is covered with carpet (S&S Mills Sequoia-20 ”scotch pine green,” “polar express blue,” and “capitol red”). The FIELD includes two BUMPS that divide the FIELD into three regions (the RED ZONE, the MIDFIELD, and the BLUE ZONE). A 2-inch wide white CENTER LINE runs down the center of the FIELD.
(since 2004)
Unread 12-01-2010, 21:42
shortone1320's Avatar
shortone1320 shortone1320 is offline
AKA: Little
FRC #0126 (Gael Force)
Team Role: Student
shortone1320 will become famous soon enough
we tried this method today with success, it was able to hold the ball as it slid along the carpet. it is a viable option for maintaining control.
good luck all!
-Rich Little
Little!
Unread 12-01-2010, 22:10
good luck all!
-Rich Little
dude epic win XD were gonna post the video on youtube, it was strong, but as said, if the ball comes off the ground when going over a ramp it will be considered a penalty...which is why they have the tunnels XD and if a team was smart ehy would have a piston or some sort of way to hit the ball...
Orbit Balls - For Sale Pelicano234 General Forum 53 02-02-2009 23:47
Alternative Method for calculating “I” term in PID Holtzman Programming 15 06-09-2006 13:22
Balls for the game K.Shaw General Forum 1 20-01-2004 17:59
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
adhesive for grabbing balls archiver 2001 1 23-06-2002 22:40
