Go to Post I do want to remind people: Safety glasses, adult supervision and don't let freshmen touch the robot. ::safety:: - rtfgnow [more]
Unread 12-01-2010, 17:01
jc4p jc4p is offline
AKA: Kasra Rahjerdi
FRC #2412 (Robototes)
jc4p is an unknown quantity at this point
Re: 2010 Camera and vision problems.
Originally Posted by s133p View Post
Ok, I feel like I am close to the solution. One thing I am seeing, after poking around in the console of the cRIO, is that it only has two network devices, the loopback, and the main one with the 10.xx.xx.2 ip. This makes me wonder how port two is supposed to connect on a different subnet to the camera.
My question then, is if one of you who has the console working to your cRIO could run "ifShow" and just tell me what things are listed. Failing that, I am at my wits end and I will have to call NI tomorrow if I cant get this fixed.
-Luke
I am in the same situation as you, sadly I do not currently have access to our robotics room to do the test for you. When I run the 2010 Image Demo code, or the snippet I sent you, the robot freezes and the Dashboard shouts "Watchdog not fed." If I comment out the initializer for the AxisCamera object, everything works.
Unread 12-01-2010, 17:51
s133p s133p is offline
FRC #0675
s133p is an unknown quantity at this point
Update: My code now seems to be able to initialize the camera without it hanging. The lights are on on the cRIO as well. To do this I re-flashed the cRIO and checked to see if the other interface was there. We also switched crossover cables, but im not sure if we needed to.
It seems like the only remaining problem is getting the video out to go back to the laptop now.
Thank you all for your help so far.
-Luke
Unread 12-01-2010, 18:57
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
-Luke
Same ;/. They had it working at the kickoff, or at least it seemed like they did.
Unread 12-01-2010, 23:20
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
-Luke
Any idea what fixed it? My code is still hanging when creating the instance of AxisCamera.
Here is the result of an inetstatShow command
PHP Code:
-> inetstatShow
Active Internet connections
(including servers)
PCB      Proto Recv-Q Send-Q  Local Address         Foreign Address       (state)
5c5f60   TCP    17376      0  192.168.0.3.1036      192.168.0.90.80       ESTABLISHED
5c54e0   TCP    17376      0  192.168.0.3.1034      192.168.0.90.80       ESTABLISHED
5c4a60   TCP        0      0  192.168.0.3.1032      192.168.0.90.80       CLOSE_WAIT
5c4520   TCP        0      0  0.0.0.0.1180          0.0.0.0.0             LISTEN
5c3fe0   TCP        0      0  0.0.0.0.3537          0.0.0.0.0             LISTEN
5c3800   TCP        0      0  0.0.0.0.43973         0.0.0.0.0             LISTEN
5c3020   TCP        0      0  0.0.0.0.1028          0.0.0.0.0             LISTEN
5c2ae0   TCP        0      0  0.0.0.0.3363          0.0.0.0.0             LISTEN
5c25a0   TCP        0      0  0.0.0.0.3079          0.0.0.0.0             LISTEN
5c2060   TCP        0      0  0.0.0.0.21            0.0.0.0.0             LISTEN
5c15e0   TCP        0      0  127.0.0.1.1024        0.0.0.0.0             LISTEN
5c1b20   TCP        0      0  0.0.0.0.0             0.0.0.0.0             CLOSED
5c10a0   TCP        0      0  0.0.0.0.44516         0.0.0.0.0             LISTEN
598a80   UDP        0      0  0.0.0.0.1026          0.0.0.0.0
598940   UDP        0      0  0.0.0.0.1110          0.0.0.0.0
598800   UDP        0      0  0.0.0.0.0             0.0.0.0.0
5981c0   UDP        0      0  0.0.0.0.44515         0.0.0.0.0
598080   UDP        0      0  0.0.0.0.68            0.0.0.0.0
value
0x1
And here's the output of an ifShow command
PHP Code:
-> ifShow
lo
(unit number 0):
Flags: (0x48049UP LOOPBACK MULTICAST TRAILERS ARP RUNNING INET_UP
     Type
SOFTWARE_LOOPBACK
     inet
127.0.0.1
     Netmask 0xff000000 Subnetmask 0xff000000
     Metric is 0
     Maximum Transfer Unit size is 1536
     0 packets received
20 packets sent
     0 multicast packets received
     0 multicast packets sent
     0 input errors
0 output errors
     0 collisions
0 dropped
     0 output queue drops
fec
(unit number 0):
Flags: (0x68043UP BROADCAST MULTICAST ARP RUNNING INET_UP
     Type
ETHERNET_CSMACD
     inet
10.3.75.2
     Broadcast address
255.255.255.255
     Ethernet address is 00
:80:2f:11:4d:14
     Metric is 0
     Maximum Transfer Unit size is 1500
     0 octets received
     0 octets sent
     204995 unicast packets received
     202032 unicast packets sent
     247 non
-unicast packets received
     2 non
-unicast packets sent
     0 incoming packets discarded
     0 outgoing packets discarded
     0 incoming errors
     0 outgoing errors
     70 unknown protos
     0 collisions
0 dropped
fei
(unit number 0):
Flags: (0x78043UP BROADCAST MULTICAST ARP RUNNING INET_UP
     Type
ETHERNET_CSMACD
     inet
192.168.0.3
     Broadcast address
255.255.255.255
     Netmask 0xffffff00 Subnetmask 0xffffff00
:80:2f:11:4d:15
     Metric is 0
     317987878 octets received
     3500254 octets sent
     218474 unicast packets received
     53020 unicast packets sent
     138 broadcast packets received
     2 broadcast packets sent
     0 incoming errors
     0 outgoing errors
     0 unknown protos
     0 collisions
0 dropped
value
26 0x1a
When I remove the call to AxisCamera::GetInstance(), the watchdog is fed correctly and the code has no problems running.
The camera has the root/admin account set up and has the default 192.168.0.90 IP address.
And yes, I am using a crossover cable.
Unread 13-01-2010, 08:10
elfinn elfinn is offline
Team 166 Mentor
AKA: Beth Finn
FRC #0166 (Chopshop Team 166)
elfinn is an unknown quantity at this point
Can you ping your camera (192.168.0.90) from the WR Console prompt?
Unread 13-01-2010, 12:29
FRC #0675
Can you post the relevant parts of your code? The includes and the camera code should be good.
Also, I don't know if the camera /works/ after starting it up, only that it starts up. I'm going to put some tracking code on today at some point and try to see if the camera is working.
Also, has anyone heard of a team actually getting the camera working/sending to the dashboard? Because I think its possible that this is a first problem. Actually, has anyone gotten "2010ImageDemo" to compile?
I really wish I could tell what is FIRSTs fault, and what is mine.
Unread 13-01-2010, 13:52
Zme Zme is offline
FRC #2619
Zme is on a distinguished road
we got the code to compile but it didn't seem to be working, held the target in front of it and it just said no valid targets, no video was sent to the dashboard. we are really confused and since this task is pretty important to us and we didn't write the code, its safe to say that we are a little frustrated
Unread 13-01-2010, 13:57
FRC #0675
Okay, I'm taking this to mean that first has the problem not us. Although, did you ever plug the camera into the computer just to make sure its focused?
Other than that it looks like we just have to wait for first to to fix it.
Unread 13-01-2010, 15:27
Zme Zme is offline
FRC #2619
i did hook it up to a computer to check to see if its focused, it was a little bit out but not all that much
Unread 13-01-2010, 15:47
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
So I get into the lab today and the camera decides to initialize itself without a problem. Still getting no image on the dashboard though. I'm not getting any other data on the dashboard either though....is anyone else?
EDIT:
Annnnnnd now it's decided to go back to not working. Can I throw this thing out of a window?
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
I'll test the Java Camera Code tonight and see if it works correctly using the v19 image and the sample code.
Unread 13-01-2010, 20:33
Kingofl337's Avatar
AKA: Adam
I tested the sample code for Java and it seems ok, but it also has some gyro code in it so I stripped that out to show the bare minimum. Here you go...
It uses the Driver Station to Output Cam X and Y values.
Unread 13-01-2010, 21:47
C++0x FTW!
FRC #1771
So I guess this means that in C++ either the example is wrong or the WPILib is wrong...
Unread 13-01-2010, 21:53
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Have you gotten the camera to at least instantiate? I can ping the camera (192.168.0.90) with 0% packet loss from the cRio, and the user/pass combo is set up correctly but my code still hangs on AxisCamera::GetInstance().
Unread 13-01-2010, 22:20
Kingofl337's Avatar
AKA: Adam
Seeing Java and C++ use pretty much the same code base, I'd think it would work in one if it works in the other, I can test the C++ code tomorrow night.
Vision problems and FIRST members ebmonon36 Chit-Chat 10 21-01-2006 22:43
vision camera Adama Programming 3 19-01-2006 17:12
71's Vision Tracking Problems Bill Beatty Rumor Mill 7 19-04-2005 17:41
Camera Vision Range Muhnki Programming 7 05-02-2005 23:26
