Go to Post ... the team that *DOESN'T* design things in the offseason for prototyping and testing will always be at a much bigger disadvantage. - Cory [more]
  #31   Spotlight this post!
Unread 11-01-2010, 22:01
TimelessFate's Avatar
TimelessFate TimelessFate is offline
Electrical Lord
AKA: Alexander Atwood
FRC #3131 (Gladiators)
Team Role: Electrical
TimelessFate is an unknown quantity at this point
Send a message via MSN to TimelessFate
Re: Effectiveness of Kicking vs. Pushing
First of all, tl;dr (Too long; didn't read)
Here is my opinion between the two.
Kicking will provide more force depending on how the robot does it. Just a regular kick, like we would do, can propel the ball pretty hard. It depends on where the kicking device stops too. We all know, when kicking a soccer ball, we can either get it up in the air or launch it across the ground. The problem I see with a kicking device is pulling the kicking device up into its resting position.
The punching method is a lot more simple and works well with the KISS method. A pneumatics piston would do the job easily. The problem I see with this is getting the piston to provide enough force to launch the ball and get it over the bumps on the field.
~Team 3131 - Gladstone High School~
~Electrical Lead & Senior Programmer~
~LabView = <3
~2007 - FRC 1510: Overdrive~
~2008 - FRC 2550: Lunacy~
~2009 - FRC 3131: Breakaway~
  #32   Spotlight this post!
Unread 11-01-2010, 22:11
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Originally Posted by waialua359 View Post
So you're doing this with your kicker NOT passing the bumper perimeter?
Proper configuration of the swing arm insures swing limited to perimeter of the bumper legally, Glenn.
  #33   Spotlight this post!
Unread 11-01-2010, 22:14
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Think about little league soccer, and design your robot so it would perform well in that environment.
That's the key here.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
  #34   Spotlight this post!
Unread 11-01-2010, 22:19
Ram Raman Ram Raman is offline
FRC #2876 (BhsRobotix)
Ram Raman is an unknown quantity at this point
Send a message via AIM to Ram Raman
Hi i am a team member from team 2876 the devil bots!
i was just wondering what you guys would say about a pusher/ short range kicker... would it be better just not to have a pusher at all?
  #35   Spotlight this post!
Unread 11-01-2010, 22:33
Electrical Lord
A pusher follows the KISS policy very well. If you guys want something simple and easy to make, a pusher is excellent.
(K.I.S.S: Keep it smart and simple)
~LabView = <3
  #36   Spotlight this post!
Unread 12-01-2010, 19:42
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
does anyone have any design ideas for a kicker?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
  #37   Spotlight this post!
Unread 12-01-2010, 20:00
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
I think pushing/punching is the closest thing you will get to being able to herd the ball without actually herding; while kicking is sorta like the shooters of last year game, one at a time...that's just my opinion..
"There's always next year..."
  #38   Spotlight this post!
CindyLouWho's Avatar
CindyLouWho CindyLouWho is offline
FRC #0360 (The Revolution)
Team Role: Scout
CindyLouWho is an unknown quantity at this point
When it comes to the percentage of who will do what type of shooter, it will most likely be pretty even. Kickers would be more beneficial to people whose strategy would be to station themselves in their opponents section, while pushing would be the way to go for most people who are focused on moving the soccer balls and scoring from a closer distance. Weight is also an important factor, considering that a kicker has more weight vs a pusher.
  #39   Spotlight this post!
Unread 12-01-2010, 20:06
kapolavery's Avatar
FRC #2445 (RoboKAP)
Or what about like..in pin ball..the swinging parts as a mechanism to hit the balls..
  #40   Spotlight this post!
Unread 12-01-2010, 20:20
Shawyan Shawyan is offline
FRC #1334
Shawyan is an unknown quantity at this point
It is my understanding that it is impossible with loads of top spin, to be able to hit the ball straight at the bump and for it to go over. (I Tried it full strength with my foot and the ball just went straight up. that is a 45 degree angle for you).
Thus, being able to kick the ball at an angle will b very important for getting the ball out of the middle. Please note, if the ball hits anywhere before the flat of the bump, it will come back.
Now, making a kicker than is angled and can also change into a pusher by becoming perpendicular to the floor..... that is a lot of moving parts, and potential problems that I do not see many teams (including ours) attempting. Also, the kicker's height could be changed, allowing for contact to be at a higher point, losing power but allowing the ball to go straight.
My $0.02
Pushing Play Without Pushing Play Res0lu7ion 3D Animation and Competition 3 12-12-2008 15:05
Poll: Dumper effectiveness at Championship The Lucas Championship Event 3 23-04-2006 00:33
Effectiveness of Casters ND4SPDLSC Technical Discussion 35 26-01-2004 23:08
Kicking a robot's bottom... archiver 2001 5 24-06-2002 00:17
H.E.R.O. Still alive and kicking. archiver 2001 0 23-06-2002 23:57
