Go to Post There are no rules specifically prohibiting the use of cryogenically preserved legumes on the robot. - dtengineering [more]
Thread Tools Rating: Thread Rating: 11 votes, 4.64 average. Display Modes
Unread 12-01-2010, 15:59
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Unhappy Wind River License Library Problem
I installed Wind River on my vista laptop but when I booted Wind River up, it has this error and goes like "License Library Missing" and I cannot access the IDE
I installed Wind River according to the pdf from the FIRST website...
What happened? Did I miss some update or something?
Unread 12-01-2010, 20:58
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Wind River License Library Problem
Wipe all traces of Wind River from your computer, take out your software CD's from the kit.
Install WindRiver again, make sure to add the license file (I forget the exact name but it's some text file that the installation will ask for, it's on Disc 2).
Don't open WindRiver yet. Restart your computer just to be safe. Download and run http://first.wpi.edu/Images/CMS/Firs...te20100107.exe followed by http://www.usfirst.org/roboticsprogr....aspx?id=10934 .
Restart the computer once more and attempt opening WindRiver. If you're still getting errors I'd recommend calling FIRST support and they'll direct you to the necessary department (might be external to FIRST).
Phone: (603) 666-3906 or (800) 871-8326 (via http://usfirst.org/contactform.aspx).
Hope I was of help, because it's a licensing issue you might want to cleanup registries after the uninstaller ~ I'd recommend http://ccleaner.com
EDIT: Oh, and of course since you're in Vista, right click on the run shortcut of WindRiver->Properties->Compatibility->Run as XP SP3 and Run as Administrator.
Unread 13-01-2010, 18:21
masoug's Avatar
Food Consumer
FRC #0114
I followed what you did but it still did not work
Here's the entire log message:
!SESSION 2010-01-13 15:08:01.981 -----------------------------------------------
eclipse.buildId=20080514-1211
java.version=1.5.0_11
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY com.windriver.ide.common.core 4 0 2010-01-13 15:08:25.076
!MESSAGE [vxworks-6.3] C:\WindRiver\wrenv.exe: cannot execute command: cmd
!ENTRY com.windriver.ide.common.core 4 0 2010-01-13 15:08:25.137
!MESSAGE [workbench-3.0] C:\WindRiver\wrenv.exe: cannot execute command: cmd
!ENTRY com.windriver.ide.common.core 4 0 2010-01-13 15:08:25.138
!MESSAGE Install registry not accessible! Please check installation.
!ENTRY com.windriver.ide.common.core 4 0 2010-01-13 15:08:25.236
!MESSAGE Could not set up License Management
!STACK 1
org.eclipse.core.runtime.CoreException: The License-Library was not found, licensing disabled
at com.windriver.tools.utils.LicMgtIntf.checkLoadLibr ary(LicMgtIntf.java:375)
at com.windriver.tools.utils.LicMgtIntf.<init>(LicMgt Intf.java:314)
at com.windriver.tools.utils.LicMgtIntf.getInstance(L icMgtIntf.java:119)
at com.windriver.ide.util.license.LicenseUtils.checkL icense(LicenseUtils.java:124)
at com.windriver.ide.application.UnifiedSWTSwingAppli cation.checkPreconditions(UnifiedSWTSwingApplicati on.java:102)
at com.windriver.ide.application.CopyOfIDEApplication .start(CopyOfIDEApplication.java:90)
at com.windriver.ide.application.UnifiedSWTSwingAppli cation.access$101(UnifiedSWTSwingApplication.java: 42)
at com.windriver.ide.application.UnifiedSWTSwingAppli cation.start(UnifiedSWTSwingApplication.java:56)
at org.eclipse.equinox.internal.app.EclipseAppHandle. run(EclipseAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.runApplication(EclipseAppLauncher.java: 106)
at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework( Main.java:508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.ja va:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:11 73)
at org.eclipse.equinox.launcher.Main.main(Main.java:1 148)
!SUBENTRY 1 com.windriver.ide.common.core 4 0 2010-01-13 15:08:25.238
!MESSAGE The License-Library was not found, licensing disabled
Please help!
This is the first time I installed Wind River, so I need full explanation!
THANKS!
Unread 14-01-2010, 15:41
AKA: Brad
#0190 ( Gompei and the Herd)
I just did a clean install on a clean system (windows xp and service packs only). The key to getting the license to work is selecting a Permanent activation when asked, then providing the activation file which is:
D:\distributions\wind river\FirstRobotics_2010_install.txt. You can see what this looks like in the attached dialog box.
That should get the licensing working.
Brad Miller
Robotics Resource Center
Unread 14-01-2010, 19:22
masoug's Avatar
Food Consumer
FRC #0114
Unhappy Re: Wind River License Library Problem
I did EXACTLY that!
But it comes out with this error:
Something went wrong while looking for the license: Overall License for the Wind River Workbench
Deatils:
See the logfile for more Information!
Here is the log file:
!SESSION 2010-01-14 16:17:00.932 -----------------------------------------------
!ENTRY org.eclipse.update.configurator 2010-01-14 16:17:10.272
!MESSAGE Unable to find feature.xml in directory: C:\WindRiver\workbench-3.0\wrwb\wrsysviewer\eclipse\features\com.windrive r.ide.wrsysviewer.analysis_3.0.0
!ENTRY org.eclipse.update.configurator 2010-01-14 16:17:10.274
!MESSAGE Unable to find feature.xml in directory: C:\WindRiver\workbench-3.0\wrwb\wrsysviewer\eclipse\features\com.windrive r.ide.wrsysviewer.vxworks5_3.0.0
!ENTRY org.eclipse.update.configurator 2010-01-14 16:17:10.275
!MESSAGE Unable to find feature.xml in directory: C:\WindRiver\workbench-3.0\wrwb\wrsysviewer\eclipse\features\com.windrive r.ide.wrsysviewer.vxworks6_3.0.0
!ENTRY org.eclipse.update.configurator 2010-01-14 16:17:10.276
!MESSAGE Unable to find feature.xml in directory: C:\WindRiver\workbench-3.0\wrwb\wrsysviewer\eclipse\features\com.windrive r.ide.wrsysviewer.vxworks_3.0.0
!ENTRY org.eclipse.update.configurator 2010-01-14 16:17:10.278
!MESSAGE Unable to find feature.xml in directory: C:\WindRiver\workbench-3.0\wrwb\wrsysviewer\eclipse\features\com.windrive r.ide.wrsysviewer_3.0.0
!ENTRY com.windriver.ide.common.core 4 0 2010-01-14 16:17:35.310
!ENTRY com.windriver.ide.common.core 4 0 2010-01-14 16:17:35.406
!ENTRY com.windriver.ide.common.core 4 0 2010-01-14 16:17:35.413
!ENTRY com.windriver.ide.common.core 4 0 2010-01-14 16:17:35.464
!STACK 1
!SUBENTRY 1 com.windriver.ide.common.core 4 0 2010-01-14 16:17:35.465
Please Help!
Is there any other alternate IDE that would work?
Unread 15-01-2010, 11:10
AKA: Brad
One last question... are you running on a 32 or 64 bit version of Vista?
Brad Miller
Unread 15-01-2010, 14:39
masoug's Avatar
Food Consumer
FRC #0114
I run 32-bit Vista Basic
Unread 16-01-2010, 02:29
masoug's Avatar
Food Consumer
FRC #0114
Question Re: Wind River License Library Problem
Is there any other way we can program the robot without Wind River but still using C++? Can I just configure normal Eclipse to do what workbench does?
'Cause I'm really tired of Wind River...
Obscure Wind River Workbench Problem {td} C/C++ 16 21-01-2010 10:11
Wind River Cds Team1710 C/C++ 0 22-09-2009 10:57
Wind River License Server Down? keericks C/C++ 4 19-06-2009 20:02
Problem with downloading Wind River beemgruem C/C++ 0 21-01-2009 12:17
Open Wind River excel2474 Programming 12 31-12-2008 17:36
