Go to Post Monkeys with typewriters will eventually create shakespeare, and spam bots will eventually create a thread title that fits the rumor mill. - ATannahill [more]
Unread 12-01-2010, 21:48
bookman101 bookman101 is offline
FRC #0219
bookman101 is an unknown quantity at this point
Question on 3 inch perimeter rule
I have been wondering how the word perimeter will be interpreted. I would like to know if you could build a u shape robot that the ball could go into the center as long as they did not invade over 3 inches in the robots actual perimeter. I was also wondering if they would interpret it a the larest square the robot can sit in. I also would like ot know if you have wheels out side the frame do they count? any help would be very apprieciated!!! thanks
Unread 12-01-2010, 21:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Question on 3 inch perimeter rule
they define it pretty well, and give an example. If you wrap a string around the robot then the string describes the perimeter.
String goes across U shaped openings, so the perimeter also goes across the opening, not into the U.
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Last I remember from the rules, the perimeter is defined as taking a piece of string and wrapping it around the robot.
So it is basically the smallest square the robot could fit in (assuming your robot is square and not a different shape all together)
EDIT: beat again.... I'll get it next time!!!! *runs off*
Unread 12-01-2010, 21:55
Frame perimeter is what you're asking about.
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
Sorry, but it's the frame perimeter that is important.
If you have wheels in the bumper zone, I'd guess they'd be some of the biggest in FRC history...
BUMPER ZONE – the volume contained between two virtual horizontal planes, ten inches above the floor and sixteen inches above the floor.
Unread 12-01-2010, 21:58
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
If the U is deeper than 3" it would not be legal.
Unread 12-01-2010, 23:04
Sixis's Avatar
Sixis Sixis is offline
AKA: John
FRC #3419 (Rohawks)
Sixis will become famous soon enough
I would have to argue from a geometric point of view the the string would not merely cross the opening of the "U" however loop around inside and measure the "perimeter". This is our first year participating and we are new to first so this may be something that has been recognized or acknowledged in the past, however I believe the "string around the robot" idea is just a basic concept that covers most generic robot shapes. The manual give this definition for the bumper perimeter: "BUMPER PERIMETER – the polygon defined by the outer-most set of exterior vertices of the BUMPERS when they are attached to the ROBOT". The frame perimeter is defined as such: "FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT". While it does go on to talk about the string, they give an exact definition for each, which further convinces me that the string is no more than a concept. I am not interesting in starting a fight, however this seems like a debatable point which is of interest to me.
Unread 12-01-2010, 23:11
FRC #1360
Originally Posted by Sixis View Post
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT.
Emphasis mine.
These words indicate that the string does not loop in a crevice or space in the robot but travels from exterior point to exterior point, making a general shape of the robot.
Unread 12-01-2010, 23:13
Yep, and because it is "exterior vertices", the inner U is not part of the frame perimeter, because it has 4 vertices: 2 are exterior (at the front of the robot) and 2 are interior (the inner side of the U).
One method that we've been using to describe this is instead of string, use a rubber band. Wrap it around the robot (in your mind--that's a huge rubber band!) in the bumper zone. Follow the rubber band; that's your frame perimeter.
As for the string being able to be pulled into the U, I believe they meant to say, "wrap a string tightly around the robot at the level of the bumper zone".
As you guys are rookies, you probably don't know about the massive debates we had last year about what was and wasn't a legal bumper configuration. It was so bad that at one point someone posted a legal configuration and the comment was made that they couldn't do that because then we'd have nothing to talk about. Look it up and see just how discussed it was--it'll be informative at worst and enlightening at best.
Unread 12-01-2010, 23:20
Sixis's Avatar
AKA: John
FRC #3419 (Rohawks)
ahh, thanks to both of you for clearing that up (before we had to debate it on the team). You would think the perimeter would be the geometric perimeter but I guess this is one of many things we'll have to learn. Cheers for the advice!
Unread 12-01-2010, 23:23
FRC #1360
no problem... I remember how much trouble the "perimeter" was last year... would hate to start it up again
Unread 13-01-2010, 06:22
FRC #0219
thanks for the help! have a great FRC season!
Unread 13-01-2010, 06:30
GaryVoshol's Avatar
Cogito ergo arbitro
All of this is really academic. It doesn't matter. The FRAME PERIMETER is defined at the BUMPER ZONE height, 10 to 16 inches off the ground. That's above the ball. If you want an indent below the BUMPER ZONE to channel the ball, it's perfectly legal. The ball will fit under your bumper.
(since 2004)
Unread 13-01-2010, 07:25
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
If I understand you correctly I think you are mistaken.
step 1) define frame perimeter (e.g. using the string method)
step 2) ball may not enter more than 3" into frame perimeter, when viewed from the top. (i.e. may not enter more than 3" into the projection of the frame perimeter to any surface parallel to the floor)
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 13-01-2010, 07:35
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
The frame perimeter also projects downward onto the floor. This is the boundary which is used for both the 3" incursion rule and the 2 second 'kicker zone' rule.
Unread 13-01-2010, 08:39
GaryVoshol's Avatar
Cogito ergo arbitro
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside the FRAME PERIMETER below the level of the BUMPER ZONE.
(emphasis mine)
But
<G46> BALL Penetration Restriction – The BALL must not extend more than 3 inches inside the FRAME PERIMETER as defined in Rule <R19>. Violation: PENALTY for a basic infraction, plus a YELLOW CARD if no immediate attempt to remedy.
They really should have repeated "below the BUMPER ZONE" here, instead of just referencing <R19>.
Nevertheless, this is the way it has to be interpreted. Else, whenever an airborne ball went above your robot, you'd be in violation.
(since 2004)
80 Inch Cylinder Question pakratt1991 Rules/Strategy 3 12-02-2008 13:35
80" inch rule m1k3 Technical Discussion 9 29-01-2008 16:09
Rule question pbrules15 Electrical 4 21-01-2008 07:19
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
rule question.... archiver 2001 1 23-06-2002 22:54
