Go to Post I would argue that you are not overdosed if you don't know the correct name of this year's game - KarenH [more]
Unread 12-01-2010, 19:53
ISGOI Howie ISGOI Howie is offline
FRC #2996
ISGOI Howie is an unknown quantity at this point
2010 kit jaguars
are the kit jaguars(not the black ones) that where shipped this year fixed?like if i look at the serial number is there a point where they had them fixed? we had big issues with them last year and want to make sure also we havent updated them or anything so i dont know if thats possible but just a thought
Unread 12-01-2010, 22:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 2010 kit jaguars
Fixed in what way? Or against what problem?
Unread 12-01-2010, 23:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
There was an issue seen last year in a small amount of Jaguars (I believe it was well under 1%) where one driving direction would be lost (either forward or backwards).
I'm working from memory, but I believe they tracked this down to a specific FET that wasn't up to snuff. You can search for the issue and find it.
As Chief Delphi commonly does though, the people who had problems complained and the people who didn't have issues didn't complain. This seems to have resulted in a somewhat slanted view of the actual failure rate.
The new black Jags have this issue remedied. We've been unable to get an answer on the gray ones so far. There is another discussion on this issue that you can find in one of the can threads where we're waiting for the answer. They (TI) may be a bit reticent because they don't want to appear to suggest that there is anything truly wrong with the gray jaguars - many teams used them pretty successfully last year.
Unread 12-01-2010, 23:14
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
To answer for Howie (we're on the same team), we had an issue with all four of our jags last year frying at the same time. We're wondering if the jags in the new kop are more reliable, ie, there's been some kind of revision to improve it with the later serial numbers (not sure the best way to explain it). We know the new black ones are supposed to be more reliable
Unread 12-01-2010, 23:27
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Does anyone else know for a fact that the black jags no longer face the same issues that was seen on last year's jaguars? Has anyone who has had time to play with the black jaguar reported any failures?
Our team needs to decide on jaguars or victors soon, and if the black jaguars are just as unreliable as the jaguars were last year, we might shell out the extra $30 each and use victors.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 12-01-2010, 23:33
Ram Raman Ram Raman is offline
FRC #2876 (BhsRobotix)
Ram Raman is an unknown quantity at this point
Send a message via AIM to Ram Raman
Quick question for anyone who went to the northeastern kickoff... does anyone know what parts from the KOP were missing?
Unread 13-01-2010, 01:34
Tom Line's Avatar
The black jaguars definitely got some component upgrades to help address some of the problems found last year.
Please note, however, that I am not going to vouch for the black jaguar's reliability. At the failure rate seen in the gray jags (very low), there simply aren't enough black jags out there among the beta testers to give a statiscal sample size worth commenting on.
Unread 13-01-2010, 23:38
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
You need to be wary of static discharge near the Jags. I suggest covering the unused pins with an insulator.
We were able to repeat failures and trace it to static.
Unread 14-01-2010, 00:30
Manchester was out of the main regulator and gloves when we picked up our kit.
Jaguars...is this ok? jngleofinsanity Electrical 15 09-02-2010 21:12
Jaguars failing Bruceb Control System 31 25-01-2010 15:40
**FIRST EMAIL**/2010 FRC Modeled Kit of Parts Now Available! Autodesk Inventor Profe Mark McLeod FIRST E-Mail Blast Archive 0 12-01-2010 10:32
**FIRST EMAIL**/2010 Modeled Kit of Parts Now Available from FRC Kickoff Sponsor PTC! Mark McLeod FIRST E-Mail Blast Archive 0 12-01-2010 10:30
