Carrying Other Robots
3132 here,
Our team is wondering if we can carry other robots on top of ours. Anyone know whether it is legal. Thanks. |
If it is legal, you would have to come up with a way to lift the robot without moving the bumpers (mounted 10 inches above ground) or breaking the frame perimeter for more than two seconds. I suggest abandoning the idea. Sorry
Re: Carrying Other Robots
i mean...yeah...i dont know if that would work...i advise against it... |
Lucky Guess???
so at the end of a match if ur on top of another robot that is off the ground does that count or do you have to be hanging from
#7
One of our concepts had another robot on top of ours. We abandoned it because of stability issues.
Thanks, timytamy |
#8
The rules state that to be Suspended a robot must only be in contact with an Elevated and/or Suspended robot. The rules make no specification as to how that contact must occur.
#9
So interesting question... Do you think that if my teams robot was suspended robot was incidentally touching the tower, would our team lose its bonus points at the end of the match?
#10
Watch out for the "Raul Rule" though. In Rack-n-Roll, you got bonus points at the end of the game for being lifted off the field on an alliance robot. Wildstang had a match with two non-functioning robots as their alliance partners. Their alliance strategy was to stack the two non-moving bots from the beginning of the match to the end, and 111 ran around the field alone. Despite a Q&A ruling earlier that this was a legal strategy, the GDC reversed their decision after this event, citing that the stacked robots were dangerous. If a stack of non-moving robots was dangerous, I'd guess they'd think it even more dangerous if you intended to move around with another robot on your back. |
#11
What happens if a red bot is on top of a blue bot and the blue bot doesn't move for what ever reason? Is that pinning?
#13
I think you will find that the answer to your question is in the starting configuration rule. One robot in each section touching a specific boundary when the match starts.
I am guessing that when you ask this question of the GDC, the answer may come from an interpretation of robot. If you drive around with another robot on yours, it could be considered one robot and as such exceeds weight, and likely size. Even if that still doesn't throw a flag, any contact with the second robot and another robot can only be in the bumper zone (of the bottom robot) and would likely garner one of the myriad penalties. <G08> ROBOT Starting Positions – Prior to the MATCH, each TEAM negotiates within their ALLIANCE to select one of the three starting areas for their ALLIANCE. When the FIELD is viewed from the ALLIANCE STATION, the ROBOTS must be placed on the right side of the CENTER LINE in one of the following starting positions: • In the far ZONE and in contact with the ALLIANCE STATION WALL and/or ramp. • In the MIDFIELD and in contact with the farthest BUMP. • In the near ZONE and in contact with the nearest BUMP. Last edited by Al Skierkiewicz : 13-01-2010 at 08:50. |
#14
If this is how it will be called, then how is it possible for 1 robot to hang from another (suspended) without incurring a penalty? |
#15
I was referring to contact between the robot on top and another robot on the field. It is perfectly conceivable that the top robot will not fit perfectly on the robot underneath and any contact with another robot would be outside the bumper zone. |
| Tipping Other robots | IdaNeStr3088 | Rules/Strategy | 3 | 10-01-2010 11:36 |
| Other uses for robots | a kenny03 | General Forum | 20 | 30-11-2009 21:18 |
| Other robots? | Andy L | Electrical | 12 | 30-04-2009 18:57 |
| Interaction with other robots | SoccerNerd36 | Rules/Strategy | 16 | 15-01-2005 15:19 |
| 'Accidently' ripping other robots apart | Vipersna | Rumor Mill | 6 | 04-01-2002 23:27 |
