Go to Post These teams aren't elitists, but they sure are elite. - [more]
Unread 12-01-2010, 12:10
CaptainMorton CaptainMorton is offline
FRC #0888
CaptainMorton is an unknown quantity at this point
How to speed up the camera
Does anyone know how to speed up the camera display?
i.e. with an accelerometer?
Unread 12-01-2010, 12:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How to speed up the camera
Good one!
Usually a camera will work faster if you reduce the size of the image you want to see. So if there is an image pixel size setting, use a smaller size.
Unread 12-01-2010, 14:18
Is the camera "speed" you are referring to the field/frame refresh rate? Or is it the ability to turn in it's mount?
Unread 12-01-2010, 23:56
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
I agree with squirrel; lowering the size of the pictures (which I believe we did last year) is the best way to reduce camera lag. In addition, any image processing being done (ie scanning the picture for a pattern/etc.) should be kept to a minimum. Do some tests, like constructing a model target and seeing how detailed it is from 60' away. If it seems really detailed, then cut down the image size. You don't need a ton of detail for the target; a 2 or 3 pixel thick black oval will do. (Cutting down the image size reduces the amount of data that must travel, and the amount of data one must sift through if one is searching through the image for a target, and the amount of RAM used).
I haven't looked in to the Camera's documentation at all, but if it offers different functions for kinds of color scanning (for example, scanning for RGB values instead of HSV), try scanning for RGB; I have *heard* that RGB functions are slightly faster than HSV, but that was on a different platform (Pascal programming) and obviously a different compiler, so take this worth a grain of salt, if even that.
FRC - Team 1885 - Programmer.
Unread 13-01-2010, 00:02
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Even better is black and white, since the targets are not colored this year. Less channels = less data transfer.
Speed of the camera nickmagus Programming 86 20-02-2009 21:40
how to limit speed on the motors. haxor5354 Programming 2 07-02-2009 07:51
