Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Unread 13-01-2010, 00:07
AlexGrant's Avatar
AlexGrant AlexGrant is offline
FRC #3928 (Neutrinos, alumnus of 3042)
AlexGrant is an unknown quantity at this point
Compass sensor
Alright i know this may be a bit out there but is it possible to get a compass sensor to work well with a robot? If so how would one go about doing so?
Unread 13-01-2010, 00:10
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Compass sensor
We tried one in 2008. Go look up some 364 video's on TBA for 2008, then come up with a conclusion.
The compass we tried was the biggest pain in the butt we've ever used. We could not find a decent place to put it on the robot, so we mounted it up top away from all the motors, then when we went under the steel underpass, guess what started tripping up.
Do yourself a favor and use a Gyro.
Some other teams may have gotten a compass working, but ours was way too sensitive.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 13-01-2010, 02:52
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Re: Compass sensor
Last year I was on 2342 in the USA, and we used a gyro. It wasn't that hard to program, and it was the main sensor we used in Autonomous mode. I would recommend using it.
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 13-01-2010, 07:56
M.Rehberg's Avatar
M.Rehberg M.Rehberg is offline
AKA: Mike Rehberg
FRC #2619 (The Charge)
M.Rehberg is an unknown quantity at this point
Re: Compass sensor
Our team used (tried to use) a compass last year. It actually did work, but as the previous post described, they can be sensitive to motors and metal. If you use one I would suggest using it to check your heading, but use the gyro to control. The gyro with the integrator provided by the cRIO is very good, and didn’t seem to lose precision through these relatively short matches.
If you still have interest in a compass, here is basically how it worked:
They started with a mems compass mounted on a breakout board from SparkFun.com The output is I2C, which the FIRST cRIO has on the digital sidecar, but we couldn’t find what we needed in the libraries to use it. So the team used an Arduino (which is an ATmega168 programmed with C), which could talk to the compass on the I2C buss, then sent an analog 0-5 volts to the cRIO that translated to 0-359 degrees. They also had to set a digital output to tell the Arduino to put the compass in calibration mode, then the robot went into a 720 degree spin. This addition seem to help quite a bit, but as I said above, they ended up using a gyro.
The learning experience with the Arduino, and I2C was great, and there is also a lesson in the difference of how well something looks on paper Vs in practice…
Mike Rehberg
Team 2619
Midland, MI
Unread 13-01-2010, 08:59
Re: Compass sensor
We have used a compass in the past. Not as effective as we had hoped. Many require a neutralizing high current pulse to demagnetize the chip and surrounding area before a read. They depend on being able to sense the earth's magnetic field and can be confused by ferrous metals and other magnetic fields. All of our motors use permanent magnets and trying to position a compass within the robot is a daunting task. Several teams have used them over the years but it does present some challenges.
Unread 13-01-2010, 16:12
AlexGrant's Avatar
Re: Compass sensor
Alright, Thanks for all the great replies guys, really appreciate everything. So what we are essentially trying to do is to get our Holonomic drive robot to maintain the same direction unless we want to change that "target direction" this will make it easier to control and also give us some cool design possibilities. How would you guys go about achieving this sort of control?
Unread 13-01-2010, 17:27
RyanN's Avatar
RyanN
Re: Compass sensor
Use a Gyro.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 13-01-2010, 18:20
AlexGrant's Avatar
Re: Compass sensor
Alright, So before this thread I always thought gyro's just measure the angle of your robot, heh. So I did some research and now I'm just wondering, how effective will the gyro you get in the KOP be at tracking your angle through the entire match? also how hard would it be to implement a system of "target angle"? If there is anything not clear with my questions just ask away and i'll explain to the best of my ability.
Unread 13-01-2010, 18:34
Re: Compass sensor
Alex,
You may not need to know the direction for the entire match. It will help target the robot or perform whatever auto function you want to run during the auto period. If you know where you are at the start of the match then you can move to another point on the field if you know distance traveled and direction you traveled.
It would also be useful if you are using the camera to shoot so that you can know where you are in relation to the goal. i.e. The robot is pointed here but the camera says I should be pointed 30 degrees to the left, so turn left another 30 degrees.
Unread 13-01-2010, 18:40
AlexGrant's Avatar
Re: Compass sensor
Yeah that is true, but what we are trying to achieve is a mode for our holonomic drive system so that it will stay in the same orientation just moving different ways, so would a gyro be able to hold that the whole match?
Unread 13-01-2010, 18:50
Re: Compass sensor
Alex,
You could do that but think about the whole game. What is your robot going to do for two minutes? Do you always want it pointing in the same direction?
Unread 13-01-2010, 19:00
AlexGrant's Avatar
Re: Compass sensor
meh, im always bad at explaining things, What you have is a "target zone" in which you can pick where to point it, so you can change it whenever you want but it will stay in that position until you do change it, and holonomic drives are drives such as mecanum and omni drives so you can strafe.
Unread 13-01-2010, 21:39
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Compass sensor
Just to be clear, the Gyro used in FRC gives you the Rate of Turning, in degrees per second. So if you want to keep your robot from turning, just maintain the gyro value at zero - if it turns at 2 degrees per second for 3 seconds, then turn it back the same 6 degrees.
Just be aware that a gyro has some "drift"; that is, it reports small turn rates even while not moving. This can be mostly managed by adjusting for temperature (there is a temperature sensor on-board) and some empirical measurements, not perfectly but well enough for a 2 minute match. Not to mention your driver can 'adjust' the actual position a little if/when necessary, leaving the majority of the work to the automated system.
Unread 13-01-2010, 21:50
AlexGrant's Avatar
Re: Compass sensor
Thanks a bunch for the info, how difficult do you think it would be to implement a system like this for a programmer with moderate experience?
Unread 14-01-2010, 07:29
Re: Compass sensor
Alex,
If your are pointed at a goal and then move left or right, the angle to the goal changes. If you stay on the same heading and move forward and back the heading to the goal also changes. It might help for you to draw out various positions on paper and then measure the different angles.
[FTC]: Compass Sensor saaby FIRST Tech Challenge 5 26-03-2009 19:56
[FTC]: Compass Sensor Interference. ttldomination FIRST Tech Challenge 3 02-02-2009 20:19
Devantech CMPS03 compass sensor eagleslg Programming 1 24-05-2008 22:00
Where can I get a digital compass sensor? EHaskins Technical Discussion 6 26-09-2007 18:33
Compass/direction sensor Frank(Aflak) Technical Discussion 10 06-04-2003 09:18
