Go to Post Chief delphi is a great way to communicate ideas, meet people, and gain knowledge is multiple fields. - Tyler Olds [more]
Unread 13-01-2010, 09:53
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Camera Target Dimensions
Does anybody have a dimensional drawing for the vision target? I have the image but no sizing information.
Thanks.
mike
Unread 13-01-2010, 10:24
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Camera Target Dimensions
Thanks.
mike
In "The Arena" section of the manual it says that the target has a 42" outer diameter with each of the white-black-white rings being 4" wide and a FIRST logo thrown in the middle of everything for aesthetics and having nothing to do with the target itself.
Unread 13-01-2010, 10:30
pribusin's Avatar
Uber Alien
AKA: Mike 1
Awesome - thanks. Obviously I didn't read the manual carefully enough.
Unread 13-01-2010, 10:41
pribusin's Avatar
Uber Alien
AKA: Mike 1
Now, is the 42" referring to the outer white circle or the black circle? If you look at the drawing, the black circle looks thicker than both the white circles. There is a drawing (GE-10059) that is referenced in the field drawing package as having details on the target, but the drawing is not included in the .zip package.
Unread 13-01-2010, 12:29
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Which .zip package are you looking at?
And it might be your eyes playing tricks on you, the manual explicitly states that all 3 circles are 4" wide...and that the three circles compose the target so the outer diameter would be to the edge of the outer white circle.
Then again they might have made a mistake in the manual, so let's find that drawing .
Unread 13-01-2010, 12:40
pribusin's Avatar
Uber Alien
AKA: Mike 1
at http://www.usfirst.org/roboticsprogr....aspx?id=16097 are 4 .zip files with a number of arena drawings etc. None of these contain GE-10059.
I drew 3 concentric circles each 4" wide and the outer white circle measuring 42" in dia. and it looks nothing like in the game field animation or the arena diagrams in the manual.
Unread 13-01-2010, 13:05
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
You have the 4" widths measuring from the outside? so the outer white circle would be 42" dia., the black would be 38" dia., and the inner white would be 34" dia., if I recall correctly.
Unread 13-01-2010, 13:28
pribusin's Avatar
Uber Alien
AKA: Mike 1
But don't forget you have two widths of 4" per circle that you have to subtract to get the inner diameter (ID). If you draw a 42" OD circle that is 4" wide your ID is: 42"-(2x4")=34". That gives you a 4" wide band as a circle with an OD of 42". That is the white ring. The black ring would then be 34" OD and 26" ID. The innermost white circle would end up being 26" OD and 18" ID. Is my thinking wrong on this???
BTW, we posted on the USFIRST forum inquiring about the GE-10059 document. Hopefully that file will clear things up.
Unread 13-01-2010, 13:29
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
the included GE-10063.pptx has what looks to be a diameter of 38 inches for the rings...
the whole thing comes out as 42 inches across though.
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Target acquisition with camera- color issues Quarkster Programming 20 12-03-2009 00:11
Camera Tracking Target Jade Programming 3 20-01-2007 01:41
Urgent help needed : Camera locks on to no apparent target! ?!?! Salik Syed Programming 11 06-03-2006 17:24
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
Camera never finds target, stays at "Searching..." Mike Programming 12 22-01-2006 12:47
