Go to Post Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three. - Billfred [more]
Unread 13-01-2010, 11:02
Re: Why you WANT to use a Gyro this year
Originally Posted by nathanww View Post
By the time aX is showing roll that stands out above the noise floor, isn't your robot in a pretty precarious situation already?
I spent about a week of December doing a tolerance analysis of using an accelerometer as an inclinometer. For the specific part I used, my conclusion was that determining pitch and roll using the X and Y axes was more accurate than using the Z axis. This was assuming a single point calibration at start up.
Who do you want to see at IRI this year? dwaynetrip3119 General Forum 71 22-04-2009 17:45
How many wheels are you going to use this year midway78224 Technical Discussion 23 14-04-2009 20:49
Which wheels will you use for your robot this year? GO Groves 1213 Technical Discussion 44 03-02-2007 12:36
Teams: How did you use your potentiometers this year? 987HighRoller Programming 11 15-05-2006 22:16
