Go to Post How about "Lebron"? Wait, no, you'll be dooming yourselves to failure the last 30 seconds of every match. - Travis Hoffman [more]
Unread 13-01-2010, 11:17
Jared Russell's Avatar
Taking a year (mostly) off
Re: Why you WANT to use a Gyro this year
Take a look at the documentation for our kit accelerometer.
If set to +/- 2g operation, we're talking a resolution of 4mg (that's milli-g's) per LSB. The noise ceiling is spec'd at worst case +/- <1.5 LSB for the Z axis, <1 LSB for X and Y (at 100Hz data rate = 50Hz bandwidth).
In other words, at a 100Hz data rate, at roll of 5 degrees (0 degrees pitch), we would expect aX to read sin(5 degrees)*1g = 0.0872 g (or 87.2 mg). That's >20 LSBs - significantly above the expected noise margin.
In other words, I think you will find the accelerometer responds EXTREMELY quickly to angular changes. There's a reason they use accelerometers like ours on SUVs to detect roll conditions to deploy airbags.
Who do you want to see at IRI this year? dwaynetrip3119 General Forum 71 22-04-2009 17:45
How many wheels are you going to use this year midway78224 Technical Discussion 23 14-04-2009 20:49
Which wheels will you use for your robot this year? GO Groves 1213 Technical Discussion 44 03-02-2007 12:36
Teams: How did you use your potentiometers this year? 987HighRoller Programming 11 15-05-2006 22:16
