Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 13-01-2010, 11:24
Xenozero Xenozero is offline
Xenozero
AKA: The inovator
FRC #1230 (Lehman Lionics)
Xenozero will become famous soon enough
Send a message via AIM to Xenozero
Where you "Cant" hang from
Hey guys, my team was trying to decide where exactly you can and cant hang from on the tower more importantly two specific areas, first is the platform itself and the second is that second lower bar on the alliance side on the tower labeled in drawing GE-10028 as GE-10028(4) support bottom. it would be really helpful to gain some insight to where you can and cannot hang considering the manual only specifies "black tape" as where you cant hang. Thanks a lot.
Unread 13-01-2010, 11:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Where you "Cant" hang from
The side of the tower that is towards your alliance station has the supports for the ball return. That's the side you can't hang from. It's also the side you could see what you're doing...
I think they made it that way as part of the challenge. have fun!
Unread 13-01-2010, 11:52
Xenozero
AKA: The inovator
cool, thanks, my team was also thinking about hanging from the two bars on the platform. To be exact, we were going to fit through the tunnel, and while in the tunnel we were going to latch ourselves onto the two rods that make up the tower platform and hang from there. Do you think in your opinion that that is legal?
Unread 13-01-2010, 11:58
MrForbes's Avatar
AKA: Jim
Did you read in the rules the definitions of ELEVATED and SUSPENDED? I can't really understand what you're describing, but if you are not entirely above the PLATFORM (the top of the tunnel) and you're contacting the TOWER then you are not gonna get any points.
Unread 13-01-2010, 11:59
Chris is me's Avatar
AKA: Pinecone
In order to get the bonus points for being ELEVATED, you need to be above the plane of the TOWER PLATFORM.
Unread 13-01-2010, 12:02
Xenozero
AKA: The inovator
Ok, thanks alot.
Unread 13-01-2010, 12:41
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
While you are right that you cannot hang from the bar at the top, who is to say that you can hang sideways on the vertical support bars? In this way you are allowed to hang from this side, which makes it easier for your drivers to orient themselves to perform the hanging operation. At the same time you're opening up more real estate for your alliance partners on the opposite side to hang and/or suspend.
Unread 13-01-2010, 13:26
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Where does it say you cant hang from the ball return side of the tower? It says you cannot hang from the ball return support rod(the lower one covered with tape) but I did not see anywhere that says you cant hang from the top rod on that side.
Bruce
Unread 13-01-2010, 14:10
MrForbes's Avatar
AKA: Jim
You're right, I was not specific enough. you can hang from the vertical bars wherever you want to, but you cannot hang from the horizontal bars on the alliance station side of the tower.
Unread 13-01-2010, 15:23
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Bruce
Both horizontal bars on that side are covered in tape, and you cannot hang from them. I think this is most clear in the field drawings.
Where to find "10 Reasons you know you've launched into Lunacy" legogeek24 Championship Event 1 24-04-2009 22:48
Can you "flip" your robot to give you a 60" width? Beamer159 Rules/Strategy 11 09-01-2008 21:12
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
Who said "BINS CANT FLY". Useless member Regional Competitions 2 14-03-2003 20:52
"PLAN B" or "IT" You Decide!!!!!! archiver 2001 0 24-06-2002 01:57
