Go to Post I hope you realize that by starting this thread you have earned yourself a permanent place at the "WOEWITWISTFT" ("What On Earth Was I Thinking When I Started THAT FIRST Trend?") table. It's members are few, but the conversation is the most honest and amusing in the entire place. ;) - Jessica Boucher [more]
View Poll Results: Attempting during the Bonus Round
Hanging Only 9 12.86%
No Attempt At Bonus Points 10 14.29%
Having a Bot Hang from our Bot 5 7.14%
Hanging off Another Bot 3 4.29%
Prepare for both options 43 61.43%
Voters: 70. You may not vote on this poll
Unread 13-01-2010, 14:02
Chris is me's Avatar
AKA: Pinecone
Re: Attempting the Bonus Round
Originally Posted by bensherman View Post
I agree. I think some teams aren't understanding the the robot has to be off the ground rather than touching the bar and the ground at the same time through a lifting system.
Without saying anything too revealing... it is theoretically possible to winch 3 robots carried on forks or other drive-on platforms up in the air. Not very fast, but faster than a single robot could score 8 balls.
The main design constraints are the 84 inch cylinder rule, weight, the 500 pound winch, and having room on the robot to accomplish anything else.
Unread 13-01-2010, 14:32
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Our team we be attempting the bonus round. We will attempt to hang with two robots on us. The details are still being work on be i think we can pull it off.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 13-01-2010, 15:44
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Originally Posted by MFennig8 View Post
See, what I have heard from some teams about a ramp idea, then also picking up multiple robots. We do have to remember that we can get the 2 bonus points for bots that hang higher than the platform or that are sitting on the platform. The one for 3 bonus points, you can not build a ramp unless your robot is hanging and is above 20" (the height of the platform). Thats where the catch comes into play. I thought about why not doing a lift up ramp like in 07", but the catch we have is that if we place 2 robots on the platform, our robot can not be holding them up at all because then the one that we are under and our ramp is holding up will not count.
Two words: Draw Bridge!
Imagine parking a robot on the platform, and extending two ramps down to the floor, allowing your alliance partners to climb up on either side. Then, use cables to pull the bridge sections up using pulleys higher up on your bot, so that the two robots are completely supported by you, and none of your robot is below the ramp. Bam, 8 points! haha mere theory of course
Unread 13-01-2010, 15:49
AKA: Pinecone
The tricky part is making a ramp wide enough for robots to drive upon, and mounting strings in a manner that pulleys can be used to lift them without robots driving on said strings...
Attempting to Drive Straight with Gear Tooth Sensors and Gyroscope Lynx34 Programming 7 13-02-2008 17:56
pic: Duece Attempting to Remove A Spoiler IraJason Extra Discussion 11 04-04-2007 23:36
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
And the Wheel Goes 'Round and 'Round Rick TYler Technical Discussion 16 09-03-2005 17:50
Height of the bar over bonus ball structure punarhero General Forum 3 17-01-2004 14:39
