Go to Post Lengthy posts are not discarded ones. Information comes in all sizes - Garii [more]
Unread 13-01-2010, 13:45
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
what wheels to use
I'm thinking about a 10 or 12 wheel chassis this year to keep the CG down but our budget is looking for less expensive wheels. Have any of you used these http://banebots.com/c/WHB-KS4-498? Not to expensive and come in 3 sizes and 3 hardnesses.
Thanks
Bruce
Unread 13-01-2010, 13:56
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: what wheels to use
I think 12 wheels are overkill. But I would go anywhere from 6 to 10 depending on wheel size. While I was talking to Sean (1771), we found out that 5 inch was the smallest wheel size you could use on a 8wd.
Personally I'd use Colsons over Banebots. 1323 is using IFI wheels this year instead of making our own due to size.
-RC
R.C.
MadTown Robotics Team 1323
Unread 13-01-2010, 13:58
Chris is me's Avatar
AKA: Pinecone
1625 used wheels of the same type and durometer (but a smaller size) to explosive results.
When in doubt, AndyMark always makes great wheels. Colsons are fantastic wheels as well.
Unread 13-01-2010, 14:24
AdamHeard's Avatar
Lead Mentor
If you're on a budget, want that many wheels, and want a real durable wheel (much more so than the banebots), I'd say Colsons are the way to go.
Robot Marketplace has a nice selection.
With that many wheels, I'd go with the 7/8" or 1-1/4" wide, and 3-5" OD due to cost and weight. You don't really need to go to the wider and heavier wheels.
Unread 13-01-2010, 14:43
Bruceb's Avatar
Looked at the colsons wheels. Whats with the wierd(29/32) bore dia? Can they be reemed out to something more available so I don't have to machine custom shafts for them?
Thanks
Unread 13-01-2010, 14:45
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Depending on your budget, I'd suggest looking at the AM Plaction wheel.
http://www.andymark.biz/plactionwheel.html
We're going to use them in Our 8WD this year, and as far as I know, they're the most affordable tread-able wheel out there at $22 - $33 a wheel - which was one of the main factors behind our decision.
Unread 13-01-2010, 15:38
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
If you go with any tread type wheels, definitely go with the rough top tread. From my team's experience, the rough top out performs the wedge top in all respects.
Unread 13-01-2010, 15:44
AKA: Pinecone
Though sometimes, you may want the "worse" tread on your robot. Say hypothetically wedgetop wheels had slightly less, but not very less, traction (I don't actually know, I'm assuming based on your above statement). Then putting wedgetop on the outer wheels and rough on the inner wheels would supplement a drop center 6wd's turning ability.
Unread 13-01-2010, 15:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes Chris we discovered that tread selection is important....not so grippy on outer wheels seems helpful for turning on carpet without killing battery quickly
Unread 13-01-2010, 15:53
Tom I's Avatar
AKA: Tom Indelicato
I stand corrected! There are practical applications of wedge top traction, and Chris just showed a creative example of it.
Did anyone use all 4 CIM motors for the wheels tennisbeast29 Electrical 30 06-02-2009 22:07
What are the best wheels to use on carpet? The GarbageMan Kit & Additional Hardware 10 09-04-2007 20:29
What kind of wheels do you use? Cpt_Dave_Lister Kit & Additional Hardware 30 17-10-2005 22:28
What kind of materials do you use for your wheels? Alex Cormier Technical Discussion 1 24-01-2005 19:19
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
