Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 13-01-2010, 14:49
MulletFish MulletFish is offline
AKA: Eric Fischer
FRC #2827 (Lambda Cubed)
MulletFish is an unknown quantity at this point
How to transfer the Build file to the Classmate
I am using another computer to write the program using WindRiver...how would I take the Build file (I don't even know what it is called!) , transfer it over to the Classmate and load the file onto the cRio?? Thanks
Unread 13-01-2010, 14:59
goodsky's Avatar
goodsky goodsky is offline
Programming Mentor
AKA: Skyler
FRC #1902 (Exploding Bacon)
goodsky has a spectacular aura aboutgoodsky has a spectacular aura aboutgoodsky has a spectacular aura about
Re: How to transfer the Build file to the Classmate
I would say to download your code from whatever other computer you are programming on instead of going through the hassle of transferring to the classmate. That would probably make version control a little bit less of a nightmare too.
Personally I still have not installed Windriver on the classmate, and am still debating if I ever will. I might just stick to the old programming laptop and leave the classmate as a drive station.
OINK OINK BOOM!!!
Unread 13-01-2010, 15:01
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
You don't transfer your robot code via the Classmate, you transfer from WindRiver directly. Read the Getting Started Guide for more information on how to set things up.
Unread 14-01-2010, 14:34
M.Rehberg's Avatar
M.Rehberg M.Rehberg is offline
AKA: Mike Rehberg
FRC #2619 (The Charge)
M.Rehberg is an unknown quantity at this point
We are using SVN for version control of our WindRiver Workbench Projects. One idea we had was to setup the Classmate with SVN so it could synchronize with any of the programmers projects, rebuild, and load them to the cRIO. It should make for more rapid development over the first few weeks when all the programmers want access to the cRIO to test their code and learn how the deployment process works.
Mike Rehberg
Team 2619
Midland, MI
how to transfer the program to the crio? beefy1 Programming 5 04-01-2009 10:04
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
[ECDU]: How involved in the build are you? Steve Howland FIRST-related Organizations 7 08-03-2005 12:12
Web-Based File Transfer? Gadget470 Website Design/Showcase 6 11-01-2004 16:41
