Go to Post Remember that though we come from different backgrounds and x, y, z, we are all on each other's side. We want people to love STEM, and think FIRST is a great tool to fulfill that desire. - PayneTrain [more]
Unread 13-01-2010, 15:31
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
The importance of Finish.vi, or lack thereof
I've been hearing for quite a while that calling Finish.vi is better than cutting power and that all device references should be closed there. What I'd like to know is why. During competition the robot is shut down in this "bad" way many times, with no messy results of Finish.vi not being called. So does it really make any difference?
Unread 14-01-2010, 01:23
lollypop2020 lollypop2020 is offline
FRC #2733 (Pigmice)
lollypop2020 is an unknown quantity at this point
Re: The importance of Finish.vi, or lack thereof
I would also really like to know this! Is calling Finish.vi better then not? Does it make a noticeable difference?
Unread 14-01-2010, 09:48
http://decibel.ni.com/content/message/4182#4182
Unread 15-01-2010, 15:35
In case the discussion on the forum isn't clear, I'll attempt to summarize.
The WPILib code for the cRIO was written so that aborting a VI will cleanly deal with closing I/O for you. This is not always the case, and some OS resources or 3rd party libraries will lock up or behave incorrectly if you misuse their API.
As a good programming convention it is a good habit to close things you open, and furthermore to strive for having resources opens and closes be consistent, easy to verify, and easy to describe to others. Rube-Goldburg devices may be fun to look at, but are not fun to debug or modify, and you don't want one in control of your resource handles.
On the other hand, simple is good, and if there are no bad consequences to writing infinite loops and letting the auto cleanup deal with resource handles, why not take advantage of it in your code.
These conflicting goals have led to the template code being a little inconsistent. It tends to contain data wires leaving infinite loops wired to close nodes. By definition, an infinite loop does not finish, thus the close will not be called. The auto cleanup is the way most handles are currently being closed in the standard LV template. Meanwhile, if a team decides to change their loop so that it does terminate, then the next thing they'd probably want is to have a close for all the resources outside the loop, so the close was placed there for that purpose -- to show where you would typically close things if/when the loop is changed.
I hope this helps explain the legal usage options.
Greg McKaskle
Unread 15-01-2010, 18:10
Thanks for closing the loop...
Planning ahead (or lack thereof) dlavery Chit-Chat 9 20-02-2008 12:44
Importance of the Rookie Chairman's Barry Bonzack Chairman's Award 5 28-02-2005 14:54
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
Teasers... or lack thereof Rickertsen2 Robot Showcase 29 30-01-2004 12:42
The Importance of Sound ComBBAT_Albrot 3D Animation and Competition 8 09-03-2002 20:33
