Go to Post What I want is to ultimately make it so that the programming is actually done before the robot is finished. Imagine that! - Danny Diaz [more]
Unread 13-01-2010, 16:05
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Re: Wheel size considerations
My team is discussing 4WD... 8" wheels and with the 29" wheelbase that we want, I just went through the calculations, and our robot will make a MAX 24.443 degree angle with the playing surface...
that is ALOT less that I had originally thought!
I dont think huge wheels would make any better improvement on this...
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 13-01-2010, 19:27
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
so what you are saying is you can do this within 1 / 1000 of an inch ?
Ed Barker
Unread 13-01-2010, 21:27
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by thefro526 View Post
We're leading towards using 6" wheels in an 8WD.
Yeah, that's where we're leaning to.
Originally Posted by sdcantrell56 View Post
Getting creative with the frame helps a lot
What do you mean, exactly...?
Unread 13-01-2010, 22:04
ttldomination's Avatar
Sunny
We, team 1261, have a couple of ideas in the mills. They are both 10WD, but not all 10 wheels can necessarily touch the ground at the same time. They are primarily to insure that we clear the bump.
Although now that I think about it..one of the 10WD designs has a potentially crippling flaw...
1648: 2013-2014
5283: 2015
Unread 13-01-2010, 22:20
Kage's Avatar
AKA: Kage
do what? climb the ramp?
no, I do not plan on designing that little tolerance...
this is just a theoretical angle based on exact numbers.
there are too many variables to call it that close. As it stands right now, our bot has about 1 and 1/2 inches of clearance over the top of the bump...
Unread 13-01-2010, 22:32
ebarker's Avatar
AKA: Ed Barker
sorry about that.. I was just being a wise guy.
If you specify something to to that many decimals that implies your working precision. When you go to college and start your lab work you have to learn to be careful with them newfangled calculators and things or you will hear about it from your prof.
In this exercise I'd say "near bout couple of dozen degrees, give or take a smidgen".
Ed Barker
Unread 14-01-2010, 15:22
Kage's Avatar
AKA: Kage
my calculator goes to like 15 digits :|
and it also gives simplified radical answers... like if I do (sin 75) it gives me (√6 + √2)∕4 lol...my calculus teacher made me disable that function
I do plan on having precision, just not that much lol...
Im hoping we can get our fame up and designed before the end of next thursday...
then we can accomodate everyone elses mechanisms, and we can get it built...last year, we didnt have a working frame till week 5
Kicking System Design Considerations NOV8R Technical Discussion 29 26-01-2010 09:02
Wheel size JanTM1191 Technical Discussion 8 11-01-2008 08:54
Wheel size poll sanddrag Technical Discussion 15 25-05-2006 15:16
Calculating Wheel Size phrontist Technical Discussion 15 07-09-2004 18:55
Calculating Wheel Size To Climb Yan Wang Math and Science 12 18-01-2004 22:49
