Go to Post Vista is like Dave's game hints. They may look good but you really want nothing to do with them... - vivek16 [more]
Unread 13-01-2010, 18:31
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Shield under bumpers allowed or not?
My team was wondering if we are allowed to have a shield under the bumpers to help keep balls from going under our robot. the shield would not go to the edge of the bumpers and would still be inside the 38-28 inch frame perimeter.
Is this allowed or must the robot stay inside the bumper perimeter?
Unread 13-01-2010, 18:33
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Shield under bumpers allowed or not?
As long as the shielding is within a vertical projection of the frame perimeter it would be allowed.
During kickoff it was specifically stated that teams should be careful to build some sort of blocking mechanism so that balls do not inadvertently penetrate the frame perimeter.
Unread 13-01-2010, 18:35
If I understand you:
You want a shield in the frame perimeter that stays inside the frame perimeter. This is legal under all the rules I can think of.
If you want one that goes out to the bumper perimeter, then <G30-A> applies.
Unread 13-01-2010, 18:41
R16> During normal operation no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as permitted by Rule <G30>.
Note: This means no “mushroom-bots.” If a ROBOT is designed as intended, in normal operation you should be able to push the ROBOT (with BUMPERS removed) up against a vertical wall, and the FRAME PERIMETER will be the only point of contact with the wall.
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside the FRAME PERIMETER below the level of the BUMPER ZONE.
I think those two rules would answer your question in the affirmative.
Unread 13-01-2010, 18:42
AKA: carroll
thanks so you are basically saying that a shield has to stay inside the frame perimeter no matter the size of the robot?
Unread 13-01-2010, 18:47
The rule points to that.
Bane Bots Gear boxes not allowed? Skute327 Motors 4 13-01-2008 12:08
Bumpers: why not? Validius General Forum 38 23-03-2006 13:46
pic: This is how you shield a shooter sanddrag Robot Showcase 2 22-02-2006 13:36
lighted switches not allowed CarpeDiem Control System 8 07-02-2006 22:16
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
